What do you think about these oil coolers? - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 16 Old 07-31-2014, 06:57 AM Thread Starter
Question What do you think about these oil coolers?
http://www.amazon.com/Oil-Cooler-Ford-Powerstroke-Diesel/dp/B00HKE622E
PPE Upgraded Oil Cooler 03-07 6.0L Ford Powerstroke
Tan 2006 F350, PSD, CCLB, Lariat, FX4
5th Wheel, Tool box, Line-X, CB, SCT X4 w/EGT probe, Sylvania Silverstars,
Blue spring, 2" leveling kit(not installed), CAT-1 ELC Coolant, PMM Coolant filtration,
BD 6 phase FICM PS, EGR cooler delete kit (not installed)
To do/get list:
Tint, 35" Mudders, Deep tranny pan, Diff covers, Traction bars, Exhaust, Fender flares
Sheepdog is offline
post #2 of 16 Old 07-31-2014, 07:04 AM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
I haven't nor do I know anyone thats used that brand before but the last company that tried to prevent clogging of the oil cooler by simply making the passages larger found that the eot temp rises significantly and that is not a good thing especially if you were to do any towing.
HP MACHINE likes this.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #3 of 16 Old 07-31-2014, 07:54 AM Thread Starter
Good call, and thanks for the information.
Also if anyone knows any links to the best price for a 6.0L oil cooler, please post them. Thanks.
To do/get list:
Sheepdog is offline
post #4 of 16 Old 07-31-2014, 08:13 AM
6 L chevy eater's Avatar
Go to the Ford dealership and order a Ford oil cooler. This is somthing u dont wana buy cheap. Its a critical peice of equipment on these truck. Spend a little xtra now. Save alot later
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #5 of 16 Old 07-31-2014, 09:03 AM
Heavy_GD's Avatar
Quoted: 1334 Post(s)
JGC = Jeep Grand Cherokee - Parts.
If you want to save a dollar go right a head.
#getwhatyoupayfor
Oilylizard likes this.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is online now
post #6 of 16 Old 07-31-2014, 07:45 PM
MWilbur516's Avatar
This is from their website. Ford specs no longer apply and a 25* delta is normal. So overheating oil is ok now.
ADT's high flow oil cooler and complete gasket set help to maintain engine oil temperatures and prolong injector and engine life. Replace your plugged up OEM oil cooler now with this high flow unit. For all Ford 6.0L diesel engines found in the Super Duty trucks, Excursion from 2003 - 2007 and E-Series vehicles up through 2010 An important note to customers - The high flow oil coolers have enlarged internal coolant passageways to help prevent clogging from casting sand and silicates the 6.0L engines suffer from. You will see elevated EOTs, and the Ford recommended 15 degree delta does not apply. After installation, an average of a 25 degree delta is normal.
Sent from AutoGuide.com App
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #7 of 16 Old 07-31-2014, 08:17 PM
crash&burn's Avatar
But it is only 99$ through amazon. Imagine the nightmares this cheap oil cooler will bring.
ODAWG714 likes this.
Shawn
2004 CC F350 - 4-5" exhaust no cat - CTS Insight with turbo timer and Egt's - EGR Delete - K&N - Coolant Filter
SCT with Custom Tunes - MTW MadMax - 190/Stock - PTP Solenoid - Blue Spring - A few mystery switches
crash&burn is offline
post #8 of 16 Old 08-02-2014, 10:23 PM
Country Mav's Avatar
Quoted: 2 Post(s)
I read the reviews... Do these reviews look similar in any way? Another review was written in a similar fashion. I'm guessing that they wrote their own reviews...
2005 F-250 Lariat FX4 CC SB
Sinister EGR Delete
Diamond Eye 5" Turbo Back Straight
OEM Gaskets and ARP Studs...
SCT X3 (Quick-Tricks tuning)
S&B Intake
Edge CTS
Full Syn 15w-40
High idle mod
PMM Coolant Filter
Rebuilt FICM with Atlas 40
2006 F-350 XL RC/Flat Bed
EGR Delete
SCT SF3 (stays on tow agg)
FARM TRUCK
Diesel spark plugs are the bestest spark plugs....
Country Mav is offline
post #9 of 16 Old 08-02-2014, 11:27 PM
2006F350's Avatar
Auto Nation
Rich
KC Stage 3, FF 190/75, UCF Ported O-Ringed Heads, Warren Comp Plus Transmission, ARP, Sinister Up & Charge Pipes, ODAWG Ported Intake, Atlas 40, IPR EGR Delete, DD RR Kit , Fass 200, BD Exhaust, Mishimoto CAC & Radiator, BPD Water Pump, OUO Bars, MBRP 4 TB SS Duals, Sinister Coolant/Oil Bypass Edge CTS w/EGT & FP, SCT X4, DC Power 190 AMP, Hellwig Sway, No Limit Cold Air, Beans Sump, Gearhead Tunes
2006F350 is offline
post #10 of 16 Old 08-03-2014, 04:18 PM
HP MACHINE's Avatar
Quoted: 105 Post(s)
Ya beat me to it, read the reviews . This is a common practice with offshore products .
When combinations of words such as " it fitted " are used and they start trying to
overwrite common sense with statements such as " 15 degrees delta no longer apply "
25 is the new norm, GOOD BYE . Put a Ford cooler in it and be done with it.
HP MACHINE is offline
