Revmax torque converters - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By madpowerstroke
post #1 of 5 Old 07-31-2014, 03:32 AM Thread Starter
strokin6L's Avatar
Quoted: 4 Post(s)
Anyone running one in their 6L? My factory one is pretty worn out...stalls around 1400rpms. Really wanna get the RCD/PI one but can't swing it right now. I see revmax has a stage 4 converter for like $600 if I desperately need one. Just not sure how they are if worse comes to worse.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #2 of 5 Old 07-31-2014, 08:01 AM
madpowerstroke's Avatar
I have one in my truck, I have a thread called "budget transmission build". So far it has been great, they say holds 750rwhp, and are great to deal with. Their more expensive unit, is in same line as the PI, and all the other big time converters, but of course comes with a price tag, I will like to try later. The sales person for the converter knows his stuff. He told he that the converts like PI and theirs are actually based off a turbo 350 GM converter, I plan on running this one until it gives up, that was part of the test.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
The Following User Says Thank You to madpowerstroke For This Useful Post:
strokin6L (07-31-2014)
post #3 of 5 Old 07-31-2014, 07:44 PM
Jeremy@TDA's Avatar
Quoted: 116 Post(s)
X's 2 on this. I have one on order to install in a customers truck next Monday. Will advise once done...
Jeremy
Owner- The Diesel Authority
Instagram- @thedieselauthority
2017 event info!!!!
2015 6.7 Platinum
Lots of NL stuff
H&S 369SXE
Spartan tuning
2006 Shorty in progress
Lots of fuel, turba and NL stuff
Jeremy@TDA is offline
post #4 of 5 Old 08-01-2014, 02:36 AM Thread Starter
strokin6L's Avatar
Quoted: 4 Post(s)
Adrian...what improvements did you notice with the converter from the stock one? Did the truck shift better, firmer/quicker lockup, accelerate faster? Also did the sales guy explain the difference between the stage 4 and stage 5 converter?
post #5 of 5 Old 08-01-2014, 08:17 PM
Improvement are as all you stated, firmer shifts, quick lock up, and accelerate faster. It also feels like more power is making it to the ground. The revmax phone gives you options, between transmissions, converters and so on, so basically when you pick converter you will be in contact will a sales person that is very well informed on converters. The guy know an extremely amount about converters and everyone else's also. The stage 4 is a stock upgrade to handle more power and towing, It is a billet unit and has upgraded triple clutches. The stage 5 is stronger by far, is larger and as he explains is same as the other like PI, Sun Coast, based off a GM turbo 350 converter. If you have anymore question I would call them, it has been a little while since talking to them, so might have somethings I forgot about.
strokin6L likes this.
strokin6L (08-02-2014)
