Fuel Sump Install - Ford Powerstroke Diesel Forum
 10Likes
post #1 of 28 Old 07-30-2014, 09:19 AM Thread Starter
Gadgetguru's Avatar
Quoted: 448 Post(s)
Garage
Fuel Sump Install
Working on installing my XDP fuel sump. The instructions say to install it on a flat area near the center of the tank. On my 38 gallon tank the only flat spot big enough is at the rear of the tank. Anyone else have any insight as to where the best place to put the sump is?
- Michael
2017 F350 Lariat DRW - SHE'S HERE!!! 29NOV16
- Click
for details
Sold 05OCT16 - 2006 F350 DRW - 175/Stock, UCF o-ringed heads, KC Stage 2 - Click
for details
'11 Ram 2500 Big Horn (Wife's), 6.7L Cummins - Click
for details
'13 XLR Hyperlite Toy Hauler 5er
Gadgetguru is offline
post #2 of 28 Old 07-30-2014, 09:28 AM
I know we sumped our mustang tanks in the rear. Fuel is forced to the rear as you travel. I would think as long as its the lowest point it should be fine in the rear
FogleDw is offline
post #3 of 28 Old 07-30-2014, 09:26 PM
snafu!'s Avatar
I mounted mine directly under the pickup tube. There is a circle in the center of the tank that is 3" it worked out really well.
Don't use the gasket that came with the xdp sump it will leak, I used permatex grey and it has been holding fine.
ODAWG714 likes this.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
The Following User Says Thank You to snafu! For This Useful Post:
Gadgetguru (07-31-2014)
post #4 of 28 Old 07-31-2014, 03:33 AM Thread Starter
Gadgetguru's Avatar
Quoted: 448 Post(s)
Garage
That's where I ended up putting it. After looking at it a bit more and realized it seals on the outside not inside, and the outside is flat.
Had to remove the bottom of the stock suction tube though because it then hit the inside ring of the sump.
I used the gasket but also used liberal amounts of Loctite oil and gas sealant/adhesive on both sides of it. Hopefully it won't leak! Thanks!
- Michael
- Click
for details
for details
for details
post #5 of 28 Old 07-31-2014, 02:46 PM
XL trash...
Merc82's Avatar
Quoted: 323 Post(s)
Did mine same as yours. No leaks yet.
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #6 of 28 Old 07-31-2014, 02:56 PM Thread Starter
Gadgetguru's Avatar
Quoted: 448 Post(s)
Garage
Good to know. As extra insurance/peace of mind, I used Ford RTV sealant around the outside seal today. No fuel in the tank yet, that's tomorrow. Have to do some research about putting the skid plate back on. I think somebody did it utilizing spacers and longer bolts.
- Michael
- Click
for details
for details
for details
post #7 of 28 Old 07-31-2014, 03:40 PM
XL trash...
Merc82's Avatar
Quoted: 323 Post(s)
I just took the cutting torch and cut a hole for the sump in the skid plate, nothing fancy. I was in a hurry. May go back and pretty it up later.
Gadgetguru likes this.
Merc82 is offline
post #8 of 28 Old 07-31-2014, 03:44 PM
Heavy_GD's Avatar
Quoted: 1656 Post(s)
Feedback Score: 3 reviews
She ain't pretty but it works
ID:	318481   Click image for larger version
ID:	318489   Click image for larger version
RollinEarly99 and Gadgetguru like this.
GD
Originally Posted by Patriot View Post
...because Patriot.
Heavy_GD is offline
The Following User Says Thank You to Heavy_GD For This Useful Post:
RollinEarly99 (08-01-2014)
post #9 of 28 Old 07-31-2014, 03:48 PM
XL trash...
Merc82's Avatar
Quoted: 323 Post(s)
^^^ about the same as mine. His lines are fancier than mine as well lol. I just used plain old marine grade fuel line and oeitiker clamps... I will change it later... Like I said was just trying to get it done within the day.
Merc82 is offline
post #10 of 28 Old 08-01-2014, 05:00 AM Thread Starter
Gadgetguru's Avatar
Quoted: 448 Post(s)
Garage
Didn't even think about that!
- Michael
- Click
for details
for details
for details
