Best coolant and Oil - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 21 Old 07-30-2014, 07:35 AM Thread Starter
TANK.'s Avatar
I'm a 7.3 guy who just stepped into the 6.0 world. I've been trying to read as much as I can and I need a little help choosing oil and coolant. I've read elc coolant is a good idea but I'm not sure what that is. I've also read that the engine runs better on rotella 5w40 then 15w40 (I always used to run Delvac and change every 3k) Any advice would be greatly appreciated. Thanks!
CHEAP, FAST, RELIABLE... PICK TWO
TANK. is offline
post #2 of 21 Old 07-30-2014, 07:46 AM
shenanigans
junior125's Avatar
Quoted: 1448 Post(s)
Garage
Caterpillar rated EC1 coolant, you can get Shell's version at your local IH dealer, I get my T6 at walmart, as well make sure that you run OEM caps and filters
Mike
2005 CCSB F250 4X4
O-ringed with H-11's, Irate T4, BW S363SX-E, Holders 175/30%, TSD Tunes, No Limit Intake, CSF Intercooler, BPD Remote Oil Cooler, BPD water pump, 7.3 Fan Adapter, BD Diesel Manifolds, 6.7 Pump, Driven Diesel RR, Built Trans w/ PI converter, Derale Deep Pan, Traction bars, AirLift Helper Bags
junior125 is offline
post #3 of 21 Old 07-30-2014, 08:02 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I'm partial to Amsoil 5w40 and I also run their coolant as well.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 21 Old 07-30-2014, 01:00 PM Thread Starter
TANK.'s Avatar
Ok sounds good I'll swing by the cat dealer and pick some up. I did get the sinister coolant filter kit too so I hope it will help clean the system out.
TANK. is offline
post #5 of 21 Old 07-30-2014, 01:05 PM
I run Delo 400 LE 15W40 and Zerex coolant. Like junior said, use OEM caps. Motorcraft filters are fine if you want to pay inflated prices for the pretty Motorcraft box. Racor is the manufacturer of the oil and fuel filters. Do a google search and you'll come up with places that have great prices on the filters. Especially if you buy them in bulk. And trust me, word to the wise. Get a coolant filtration system on your rig. Unless you are used to swapping oil coolers they can be a real pain in the A$$!!!
2006 F250 6.0 ltr
Egr cooler/Egr delete
3.5" stock down pipe with a no name 4" straight pipe, resonator and muffler deleted. Because let's face it, exhaust pipe is exhaust pipe no matter whose name is on it
SCT X4 Tuner -
Looney Tune by QuickTricks
Fuel Pressure Regulator Blue Spring Upgrade
PPE Oil Cooler
BD-Power Coolant Filtration
Zerex EC-1 Coolant
Delo 400LE 15w40
JohnnyJackMac is offline
post #6 of 21 Old 07-31-2014, 10:59 AM Thread Starter
TANK.'s Avatar
I did get cat coolant. If I drain the system for egr am I ok to jus add the cat coolant? I heard it should not mix.thanks
TANK. is offline
post #7 of 21 Old 07-31-2014, 11:09 AM Thread Starter
TANK.'s Avatar
Sore just got premix for $9.95 a gal from cat!!
TANK. is offline
post #8 of 21 Old 07-31-2014, 11:09 AM
Not quite sure what you are trying to ask???
2006 F250 6.0 ltr
SCT X4 Tuner -
PPE Oil Cooler
Zerex EC-1 Coolant
Delo 400LE 15w40
post #9 of 21 Old 07-31-2014, 04:19 PM Thread Starter
TANK.'s Avatar
If I mix it with the stuff that's in there will it congiel?
TANK. is offline
post #10 of 21 Old 07-31-2014, 05:09 PM
Flush it as best you can. Easiest way to do it is in the drive way with 10 minute flush. Drain as much as you can out of the radiator. Put flush in. Fill with water. Go drive for 10 minutes. Park it. Drain it. Refill with water. Run it. Drain it. Fill with water. Repeat it a few times. Then drain and fill with ELC. Just change coolant in about 6 months and all that gold coolant will have been filtered and drained out. Doesn't have to perfect. Just close enough for govt work
