Oil cooler recommendations - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-29-2014, 09:54 PM Thread Starter
I am getting ready to put head studs in my 05 6.0 within the next 5k or so. I already have my studs and gaskets, I would like everyone's recommendation on which oil cooler to use? I'm thinking of the bulletproof one. Is there any others out there that people have had good success with? I don't want to have this thing apart again so I won't to do it right the first time. Thanks!
adrouse is offline
post #2 of 8 Old 07-29-2014, 09:58 PM
The bulletproof one is the only real option that works. Wish I would have went that rout. My factory replacement clogged within a couple thousand miles.
Casey
05' F350 cclb born 12-9-04
4 inch down pipe, 5 inch exhaust no cat
atlas 40 ficm tune, SCT tunes, Dashboss
ARP studs, egr delete ,driven diesel regulated return, WPE up pipes
Warren 175/75? ( wish I knew the nozzle size! )
MTW stage II turbo ( this week )
Six inch lift and 35-12.50-18 AT-II's
slvr bullet is offline
post #3 of 8 Old 07-29-2014, 11:03 PM
mossyoak's Avatar
Ford oem with elc coolant. Run a filter on the coolant and flush out the system before you do it. The bullet proof one is the best, I just couldn't see spending that kind of money when you could get alot of other goodies.
all the bullet proof things done, cat antifreeze, stock sticks, powermax / batmowheel, Tony Wildman tunes.
mossyoak is offline
post #4 of 8 Old 07-29-2014, 11:12 PM
knuckledragger5's Avatar
Quoted: 9 Post(s)
I went BPD and am very happy. The $$$ hurt but its quality and design gives me peace of mind. I also did a flush and went to rotella ELC and a XPD coolant filter. Good luck
2016 Platinum Tri Coat CCSB F250 Lariat Ultimate, FX4, Factory 20's with the TOYO ATII's
damn trucks loaded, seriously! it has heated rear seats! WTF!
***SOLD***
06 F250 CCLB Lariat FX4
por vida
knuckledragger5 is offline
post #5 of 8 Old 07-29-2014, 11:28 PM Thread Starter
Thanks everyone I guess I'll go with the bulletproof. I'm going to do that studs and egr delete the truck only has 127k and one cooler replacement at 80k I guess I've been lucky. Any other suggestions to replace while I got it down to the heads for longevity? I'm not looking for a hot rod just don't want to touch the engine again besides for little things. It already has the blue fuel spring and a new turbo at 110k so I'm pretty sure I'm good with the other issues unless anyone has any other thoughts
adrouse is offline
post #6 of 8 Old 07-29-2014, 11:36 PM
Quoted: 9 Post(s)
Right on, there are some update parts back by the HPOP, STC fittings and such. Its best to do it like you are and be done. make sure to post your progress!
***SOLD***
por vida
post #7 of 8 Old 07-31-2014, 11:40 PM Thread Starter
Will do. What is everyone's opinion on the cold weather option in the bulletproof kit. Is it really needed? The truck will be driven in north florida. So the coldest it will ever see is low 20s. I usually let my truck run for 10-15 min in the mornings while I get ready anyways so I don't really see a need for the thermostat. What is everyone else's opinion?
adrouse is offline
post #8 of 8 Old 08-01-2014, 05:10 AM
Quoted: 50 Post(s)
The usual guidance is that unless you routinely see snow plows in the winter time where you drive that you do not need the cold weather kit.
I would recommend getting the heavy duty cooler from BPD. In hot places the more oil cooling the better. I have the Tall version.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
