Updated EGR Baffle/Diverter - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-25-2014, 11:44 PM Thread Starter
SAILOR97's Avatar
Below I included the description of what I bought. When I received it it didn't have any install instructions which I realize is pretty straight forward except for the wide washer type o-ring. Do any of you guys know where that installs at? As the kit includes the 2 plates and large o-ring that goes on the air intake manifold horn. Then the 2 orange o-rings (which I get) but then theres the wide washer type o-ring and am unsure where that goes on the EGR valve. Thanks for the help
Genuine OEM Ford 6.0L Powestroke Diesel EGR Valve*O-ring Kit & Baffle / Diverter*Upgrade
This kit allows you to pull the EGR Valve, clean it and install*the Baffle upgrade/update.****
*The Baffle/Diverter helps to keep the EGR Valve cleaner by preventing carbon build-up and diverting stones/chunks of carbon build-up from passing through the EGR Valve.*
P/N -*6C3Z-9P449-A & 3C3Z-9P455-AB
Edge CTS Insight w/turbo timer, EGT probe, Fuel pres., SCT X4, DC Power 185 amp alt., NUC Motorsports deluxe oil bypass, Rotella 5W-40 W/Rev-X, Sinister Coolant Filtration, ZEREX CAT ELC-1, Dual Exhaust Stacks.
SAILOR97 is offline
post #2 of 6 Old 07-26-2014, 04:21 AM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
Pics would be nice. The only "big" o-ring around is the one that goes between the intake manifold and front engine cover
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #3 of 6 Old 07-26-2014, 10:11 AM Thread Starter
SAILOR97's Avatar
OK I will take a pic and post it...it reminds me of wiper sleeve and its the diameter of the EGR valve that goes in the manifold
SAILOR97 is offline
post #4 of 6 Old 07-26-2014, 03:39 PM Thread Starter
SAILOR97's Avatar
OK here's a pic of it..feels almost like lead...but haven't opened the package yet...got so many projects on the truck going on don't wanna mix any of it up
SAILOR97 is offline
post #5 of 6 Old 07-26-2014, 04:25 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Oh that, okay, that's the EGR valve gasket. the 2 O-rings go on the body of the valve, that gasket seals the valve against the intake when you tighten the two small 8 mm bolts
-Matt
2015 F-250 XLT 6.7L
post #6 of 6 Old 07-26-2014, 04:27 PM Thread Starter
SAILOR97's Avatar
Ooooh OK...I must have missed that or my EGR valve is missing it..haha...thanks a lot bud
SAILOR97 is offline
