stock stick finally went bad time to update ? - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 19 Old 07-23-2014, 07:23 PM Thread Starter
Ok guys the stock injectors are finally done at 220,000 miles. I'm thinking of going with Warren injectors rebuild. Just need them really fast army is moving me to alaska in 6 weeks. Now the truck is not studded and has a mtw hybrid turbo will the truck hold 155 stock nozzles or am I looking to blow a head gasket and should just stick with stock ones.
03 f-250
blue spring
4inch turbo back exhaust
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
155/stock holder diesel
tatertot is offline
post #2 of 19 Old 07-23-2014, 07:56 PM
Pro fuzz's Avatar
Quoted: 29 Post(s)
I've been running 155/stock full force inj on stock head bolts w/ PHP 140 tune for over 50,000 so far no issues it's all on how u drive it ! Also running a billet wheeled P Max and I tow 15000 lb toy hualer on his heavy tow tune !
2006 F350 KR cclb 155/stock full force powermax / WWII leveled carli 2.5 pintops 08&up full rear spring ouo 3link arms 36 toyo mt 4.30 yukon grizzly rear locker :yike
s:
New ride 2015 tow boss dpf & egr lost !!
Pro fuzz is online now
post #3 of 19 Old 07-24-2014, 07:35 AM
peixinho's Avatar
Quoted: 196 Post(s)
IMO if you have 220,000 miles on your injectors and you are starting to have problems... then I would look at getting a new set from Ford and having those built by Warren Diesel. There is only so much you can do with a really old problematic set of injectors because we are not able to replace all the parts like in an actual remanned injector
Pro fuzz and Merc82 like this.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #4 of 19 Old 07-24-2014, 07:49 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
Plus with it being an 03, the plungers were also prone to wear due to carbide vs DLC coating. Get the Motorcraft remans and have them built.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 19 Old 07-24-2014, 01:35 PM Thread Starter
Thanks guys going to go with Warren still deciding on the 155/30's just wondering if the MTW hybrid with 4in exhaust will be able to handle the EGT while pulling 10,000lbs up to Alaska got some big mountains to go over. I know on stock injectors I can do it just fine. But I have always told myself if these went time to improve.
03 f-250
blue spring
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
tatertot is offline
post #6 of 19 Old 07-24-2014, 01:41 PM
peixinho's Avatar
Quoted: 196 Post(s)
go with 155/stock. They are cheaper and will help control egts better through high efficiency and better atomizaion. The stock nozzles are plenty big enough to dump 155cc of fuel.
I will not venture into the hybrid turbo questions because people have had mixed luck with that version of a turbo. Some loved it and some hated it. It is hard to say what it will do with 155s
KC Turbos
peixinho is offline
post #7 of 19 Old 07-24-2014, 02:01 PM
madpowerstroke's Avatar
Here is my suggestion, get with me so a plan can be made for your time line, while you have truck torn down I can upgrade the turbo for you. I do offer a upgrade for the hybrid to the stage 2, and have gotten great feedback. The upgrade is free, if you are the original buyer, and if not just small cost. You would still have to pay shipping your turbo to me.
As far as injector go, I would contact Warren to see time line for your injectors versus get a set of new to send to him. I also agree not to get bigger nozzles on the 155, the price would be much lower and would work really well.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
post #8 of 19 Old 07-24-2014, 02:11 PM Thread Starter
Mad I will give you a call later. I am very pleased with the Hybrid. Guess i'll go with the 155/stock injectors thanks guys.
03 f-250
blue spring
egr delete
MTW HYBRID
SCT livewire
scan gauge w egt
zoodad mod
fuel press gauge
225,000 miles
tatertot is offline
post #9 of 19 Old 07-24-2014, 03:00 PM
PuFFeR(O_O)))><'s Avatar
peixinho what parts are not replaceable I am interested in doing/modding my injectors can you or some one point me toward info on the injectors and how to rebuild ? I am a machinist and can make any part and have a great tool guy that will coat anything in anything . A print or a 3d model would be awesome .
F250 05 CCSB
ARP studs
MTW S1
4.0 Turbo back
EGR delete
coolant filter
blue spring
6.4 banjo bolts
Innovative Diesel Tuned
PuFFeR(O_O)))>< is offline
post #10 of 19 Old 07-24-2014, 03:08 PM
peixinho's Avatar
Quoted: 196 Post(s)
It is not the fact that they are "not replaceable". It is the price and availability of parts. So when you send off "your injectors" to get rebuilt. The injector builder will do his best to work with what you have. For the price you pay for an injector builders standard rebuild... you will not get back all new parts. You will get back your same injectors with any majorly damaged parts replaced. But they don't/cant replace every slightly worn part. This usually gets you a 6 month warranty and some people have had the injectors start to have problems again after a year or so.
With a Ford Reman (not alliant) you will get back an injector that has "mostly" new parts and it comes with a 2 year warranty. I have never met anyone that had issues with getting Ford Remans rebuilt by an injector builder.
Here is a general rule of thumb that I tell my customers:
If you have no problems then get a standard rebuild
If you have slight stiction then get new upgraded solenoids
If you have bad/dead injectors then get new remans
bgraiders323 likes this.
KC Turbos
peixinho is offline
