Removing EGT probe - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-23-2014, 12:00 AM Thread Starter
Removing EGT probe
Hey guys, so here is the deal.
I bought an 05' F250 a couple weeks ago, and it had a banks 6 gun w/ the speedloader option (includes an EGT sensor). I removed it along w/ some other undesirable mods on the truck.
I wanna put an edge insight cts on it for monitoring as well as get some custom innovative tunes. I also would like to run an edge EGT probe and was hoping the mounting boss in the manifold already would accommodate the edge. I could not get that thing out of the manifold, i was afraid it was going to break it so i used a 1/4" compression cap and sealed it off.
The issue is Edge uses an 1/8" compression fitting while the banks is a 1/4". If i could get the banks piece out i'd put a sleeve around the edge piece and use the same hole. Any ideas? it has been in since 06'.
Is my best bet redrilling the drivers side manifold(driver side has the 1/4" bung in it) and starting new, or drilling the passenger side manifold?
Zach
zgzmithr is offline
post #2 of 4 Old 07-24-2014, 04:27 PM
All-Right Hauling & Trans
TurboMustang370's Avatar
Quoted: 13 Post(s)
I've done it. Soak it with penetrating oil half hour before starting.
2004 Ford F-350 XLT Dually: crew cab, 8' box, Sinister Mfg. EGR delete, NUC/Amsoil by-pass oil filter, DC Power 185 w/ FICM Repair's full wiring kit, Diamond Eye exhaust, Techni-Cooler, SCT/Gearheads tuning, Edge Insight CTS w/ EAS EGT & FP, Tekonsha Prodigy P3, Line-X and B&W turnover gooseneck.
TurboMustang370 is offline
post #3 of 4 Old 07-24-2014, 05:57 PM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
Heat it up with a torch tell almost red and spray it with wd-40. It will smoke a lot but won't catch on fire. Then find a good 6 point socket and start wrenching.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 4 Old 07-24-2014, 06:06 PM Thread Starter
So edge told me that while the NPT that goes into the manifold is different, the compression fitting that the probe screws to is the same, we will see, if not i will attempt to remove it and put a pushing on the new piece.
zgzmithr is offline
