ford gold? or cat? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-22-2014, 04:42 PM Thread Starter
strokethis1121's Avatar
ford gold? or cat?
i want to put the cat coolant in my truck but don't know where to get the model or purchase id number for that certain coolant, any leads would be helpful
strokethis1121 is offline
post #2 of 12 Old 07-22-2014, 06:11 PM
When looking for a Cat EC-1 approved coolant, I'd recommend that you get a silicate/nitrate free product. There is some evidence/speculation that the (drop out of) silicates leads to the oem oil cooler passages getting plugged.
I was able to order Peak Final Charge Global from the local O'Reilly Auto Parts. They needed to order it out of their 'heavy duty/commercial' catalog.
PEAK COMMERCIAL & INDUSTRIAL | FINAL CHARGE | EXTENDED LIFE COOLANT/ANTIFREEZE | AVAILABLE PRODUCTS
Others have used the Rotella Ultra ELC, Delo Extended Life (Nitrate Free) or Zerex Extended Life products.
Most auto parts stores will have no idea what you are talking about when you ask about a coolant with the Cat EC-1 rating. Going to a 'truck' parts place is usually the best way. e.g. locally, I can go to an International truck supply.
2015 F350 Lariat 6.7 CCSB FX4
Former trucks
2015 F250 XLT 6.7 CCSB
2004 F350 Lariat 6.0 CCLB DRW
2001 F250 XLT 7.3 CCSB
2civicrr is offline
post #3 of 12 Old 07-22-2014, 06:26 PM
Quoted: 50 Post(s)
As noted above, any ELC coolant with a CAT EC-1 spec is what you want.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #4 of 12 Old 07-22-2014, 06:57 PM
gone6.0's Avatar
Quoted: 12 Post(s)
the reason the gold coolant plugs the coolers, is when air gets into the system, via blown head gasket or air lock when flushing the coolant, the air causes the coolant to gel. This is the reason alot of coolers fail with the gold coolant.
2004 F250, SCSB, APR studs, Banks intercooler, Edge Insight, SCT with tune from Eric, atlas 40, deleted, 2" leveling kit, coolant filter, 6.4 banjo bolts with blue spring, Harpooned, Nathan K5LA. Nations 190 amp alt.
Twin Viair 480C's. BOSS superduty 8' poly plow.
gone6.0 is offline
post #5 of 12 Old 07-22-2014, 08:26 PM
Quoted: 50 Post(s)
Gold coolants also have some amount of silicates. Silicate contributes to the fouling of oil coolers and radiators.
Icon 2.5 CDC Shocks
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #6 of 12 Old 07-22-2014, 08:52 PM
ZMANN's Avatar
Quoted: 1343 Post(s)
i would like to see some documentation of the Air being the reason for the gold having issues
this is the first I have ever heard that theory
I went to Cat ELC EC1 coolant using concentrate ( just mix your own for 50/50 )
i did this because my relatively new fill of G05 ( gold) went to goo and solid dropouts on a perfectly fine cooling system)
here is the part #
We Miss you Ronnie
ZMANN is online now
post #7 of 12 Old 07-23-2014, 08:47 AM Thread Starter
perfect exactly what i needed thank you
post #8 of 12 Old 07-23-2014, 09:08 AM
snobdds's Avatar
Quoted: 9 Post(s)
I personally want some silicates in the coolant. It prevents cavitation in the soft aluminum of the front cover behind the water pump.
There is nothing wrong with the Ford Gold. Silicates fall out of suspension due to heat changing the chemical makeup.
As long as a person knows this and changes the radiator fluid more often, there should be no issues with plugging up an oil cooler.
We have work trucks with the 6.0 that get a once a year drain and refill with ford gold. These trucks never have had an oil cooler problem...
snobdds is offline
post #9 of 12 Old 07-23-2014, 09:53 AM
Term3's Avatar
All coolants have additives to help prevent cavitation but not all use silicates to do this.
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #10 of 12 Old 07-23-2014, 10:07 AM
ZMANN's Avatar
then my ford gold with less than 10k turned to goo for no explainable reason
it was premix from new bottles in a perfectly fine cooling system
i choose to avoid that future potential all together and I drank the red ELC koolaid
We Miss you Ronnie
ZMANN is online now
