Sterling 10.5's Last Chance. FAIL! - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 29 Old 07-21-2014, 07:36 PM Thread Starter
ZIKA's Avatar
So I got my motor all dialed in this past winter and the trans built this past May but my Dana 80 still hasnt found its way into the truck yet. I havnt pulled all year knowing that the rear axle was probably going to break but my 80 is finally ready to put in so I though I would give the Sterling one last shot. There is an annual pull in Ohio that is pretty open to whatever just no added weight.
Well the Sterling lasted about 293' and decided it had enough and popped yet another shaft. Sterling is Junk! Hopefully I can get the axle pulled tomorrow and get this thing underway.
I put a video up but the quality is pretty bad but you'll get the idea.
What I can say is the truck is a beast! i couldn't even give it full throttle untill about 200' which resulted in about 4600RPM's... oops. If nothing else, it sounded mean! Take look!
https://www.youtube.com/watch?v=Gqr7...ature=youtu.be
JesseKK likes this.
06 F250 Reg Cab. ARP's, RCD Billet Powermax, Warren 190/100's, Areo A1000 Pump, Driven Diesel Reg Return, All AN Lines from the sump, Intake and Exhaust, 4" BDS Lift, Long Arm 4-Link, Dana 80 swap, 1480 u-joints, 4"/.108 driveline, Detroit Lockers (both axles), Warren Trans w/ Billet Shafts, Drive Flanges, 35"s, Traction Bars, Front Suspension Stops(For Tug-A-Truck), Rear Suspension Stops, Custom Hitch, Roll Pan, Lots of Drive Shafts, Axles, and Pinions.
ZIKA is offline
post #2 of 29 Old 07-21-2014, 08:09 PM
portcity_gt's Avatar
Quoted: 1461 Post(s)
My truck will never see a sled...but I sure like my 80
ZIKA likes this.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #3 of 29 Old 07-21-2014, 08:21 PM Thread Starter
ZIKA's Avatar
If I had a Dually that looked as good as your, it would either...hope fully with the axle and the new driveshaft the truck will be pretty rock solid. It has been driving me nuts not pulling all year but I figured with the axle all done, why not? That is the 7th time that thing has broke. When I put the axle in, I am lowering it 2" and dropping down to a 35 to minimize axle stress.
Name:	Axle Almost Done.jpg
ZIKA is offline
post #4 of 29 Old 07-22-2014, 05:50 PM
DesertSmoker's Avatar
My ol ranger with its 2.3 could of pulled sled better than that............
Just kidding.
Cant wait to see what you do with the Dana 80...... Truck sounds real mean!
For Sale--2003 F-250 CC 4x4 SB 6.0
Custom 03 Turbo, WPE Intake,
HD 97 Fan Clutch, MBRP Y Pipe,
Scangauge II Rancho 9000XL,
BFG 285/75 R16, Galaxy 94HP
DesertSmoker is offline
post #5 of 29 Old 07-22-2014, 06:06 PM Thread Starter
ZIKA's Avatar
And it would have gotten 40mpg doing it to.
ZIKA is offline
post #6 of 29 Old 07-22-2014, 07:56 PM Thread Starter
ZIKA's Avatar
Started to take the axle out tonight but also did a little tear down. Another shaft. This time it was the pass side.
ZIKA is offline
post #7 of 29 Old 08-01-2014, 07:27 PM Thread Starter
ZIKA's Avatar
I ordered my pmf rear lift blocks today with new u bolts today. Hope they're sweet because they sure weren't cheap... Anyone out there running a four inch lift? What size is your rear lift block?
ZIKA is offline
post #8 of 29 Old 08-01-2014, 08:45 PM
jmeaby's Avatar
Quoted: 16 Post(s)
what axles came in which years just wondering. i thought both front and rear were dana
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #9 of 29 Old 08-01-2014, 11:35 PM
fordboy11's Avatar
03-04 up front is 32 spline Dana 60
03-04 rear single wheel 32 spline 10.5
05-07 Dana 60 35 spline
05-07 sterling 10.5 35 spline
Also a front axle on a 05-07 is heavier.
2005 F-350
Big thanks to Warren Diesel
fordboy11 is offline
post #10 of 29 Old 08-02-2014, 04:27 AM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
truck looked like it was hooked real good till the end when it started to bounce a bit then it broke. how have you kept from twisting the center section on the tubes? usually these sterlings twist on the tubes before the break.
id like to have the AAM 1150 out of a dodge with theyre limited slip. those are massive and the limited slip puts the fords to shame. just would cost a fortune to have custom hubs made to get the 8x170mm lug pattern
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
