190/75 powermax tuning? - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By mossyoak
  • 1 Post By ODAWG714
post #1 of 6 Old 07-20-2014, 05:56 PM Thread Starter
mossyoak's Avatar
I'm in the process of putting in 190/75 injectors, I have a powermax turbo. I will also be installing a fuel system with regulated return. I did a rollback on the ECM, and got the atlas 40 on the FICM. My question is- Does anyone have the same setup and if so who did you go with on the tune? Any input would be appreciated. I will be changing turbos next year, so I just would like some input on this for now. Also truck is studded, deleted, and putting in New oil cooler. I have ran vivians and tony Wildman tunes before but have to have new tunes written because of the rollback.
all the bullet proof things done, cat antifreeze, stock sticks, powermax / batmowheel, Tony Wildman tunes.
mossyoak is offline
post #2 of 6 Old 07-21-2014, 11:58 AM
peixinho's Avatar
Quoted: 193 Post(s)
Tunes is a very interesting subject. I have never personally run your exact setup... but I have been close enough.
The tunes will vary so much from truck to truck and from tuner to tuner... that you can only get a general idea from other peoples experiences.
I have about 40-50 different tunes for my truck. I have found that each setup I have tried that I like a different tuner... Basically the characteristics of the tune can be very different so I don't use the same tuner/tune for any of my setups. You will have to learn a personal preference.
With 285/75s and stage 1.5 turbo I like canned SCT performance tunes
With 285/75s, twin pumps, stage 3 turbo, and ANDY warren tranny I like Drew and tony wildman tunes
With 175/75s and stage 3 turbo I loved my TSD tunes
With 175/stock and stage 3 turbo I loved my IDP tunes and Gearhead tunes
Anyways... I am not sure if that helped or not.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is online now
post #3 of 6 Old 09-18-2014, 08:28 PM Thread Starter
mossyoak's Avatar
Thanks for the advice, I'm going to start with TSD then go from there. I have Vivian's and Tony's tunes so I will get them to revised and try them too. Again thanks PEIXINHO
mossyoak is offline
post #4 of 6 Old 09-18-2014, 08:33 PM
04cr450's Avatar
try gearhead if you get a chance. when i had a powermax with my 75% nozzles, matt had the truck dialed in very well. tsd also wrote me great tunes for that setup. both tunes felt very similar
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #5 of 6 Old 09-18-2014, 08:35 PM Thread Starter
mossyoak's Avatar
Thanks! I have found out that this is a game and you never stop playing LOL
ODAWG714 likes this.
mossyoak is offline
post #6 of 6 Old 09-18-2014, 09:54 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Ain't that the truth! Better say bye to the old lady cause the truck is gonna be getting all the attention lol
SuperrStroker likes this.
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
The Following User Says Thank You to ODAWG714 For This Useful Post:
mossyoak (09-19-2014)
