Did I forget anything on my build. - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 12 Old 07-19-2014, 04:00 PM Thread Starter
2006F350's Avatar
I'm starting out with a 6,300 mile 06 F-350 KR
It will be getting all the usual bulletproofing smalls like gaskets, STC fitting, new factory OC, EBPS, GP harnesses, feed line, return tube etc.
ARP Head Studs
Mishimoto Performance Intercooler
KC Stage 3 Turbo 67.8x94mm .72ar cc 74x70 GT40 10 Blade
WPE Stage 2 Ported Intake Manifold
Casserly Full Force 190/30 Injectors
Driven Diesel Regulated Fuel Return System Kit
SCT X4 Custom Tuner w/Eric’s & Vivian’s Tunes
Sinister Diesel Turbo Y-Pipes (up) Stainless
Sinister Coolant Filter Kit
Sinister Diesel Bypass Oil Filtration Kit
Sinister Diesel Ford Intercooler Charge Pipe Kit
Sinister Diesel High Flow Intake Elbow
Edge Insight CTS
Edge 98603 EAS Starter kit w/ EGT Cable for CTS
Edge 98607 EAS Pressure Sensor 0-100 PSI
MBRP 4” Turbo Back Cool Duals Off-road T409 Stainless
MBRP T5053 5" Dual Wall Exhaust Tips 304 Stainless
BPD Billet Water Pump
FORD 8C3Z4033A Differential Cover
Mishimoto Baffled Oil Catch Can
Bullet Proof Diesel Billet Fuel Filter Cap
IPR EGR Delete Kit w/Up Pipe
IPR HPOP Extreme Duty Stainless Steel Screen
DC Power 190 AMP HD Alternator
DC Power Big 3 Oxygen Free Copper Cable Kit
FICM Ultra/Atlas 40
Rotella ELC Antifreeze Concentrate
Bakflip F1 Tonno Cover
Functional Ram Air Hood
2008 Tow Mirrors
Pioneer AVIC-8000NEX
Boyo VTL425 Ultra Slim Black Bar Type License Plate Camera
Brite Box 8FLC5
Hellwig 7268 Big Wig Rear Sway Bar
AMP Research Power Steps
Rich
KC Stage 3, FF 190/75, UCF Ported O-Ringed Heads, Warren Comp Plus Transmission, ARP, Sinister Up & Charge Pipes, ODAWG Ported Intake, Atlas 40, IPR EGR Delete, DD RR Kit , Fass 200, BD Exhaust, Mishimoto CAC & Radiator, BPD Water Pump, OUO Bars, MBRP 4” TB SS Duals, Sinister Coolant/Oil Bypass Edge CTS w/EGT & FP, SCT X4, DC Power 190 AMP, Hellwig Sway, No Limit Cold Air, Beans Sump, Gearhead Tunes
2006F350 is offline
post #2 of 12 Old 07-19-2014, 05:12 PM
Jeremy@NoLimit's Avatar
Quoted: 110 Post(s)
Damn you KR has only 6300 miles?! Where'd you find that? I thought I was a rare one when I found my '07 last October with 22k on it. Anyway, sounds like a solid build!
Jeremy
2017 event info!!!!
-Jeremy- No Limit Fab
Sp@rtan, SCT, GH, PIP, H&S
Orders-1 800 581 8986
My direct line (706)549-5355
".org5" coupon code/discount for powerstroke.org members!
2015 6.7 Platinum
Lots of NL stuff
H&S 369SXE
Spartan tuning
2006 Shorty in progress
Lots of fuel, turba and NL stuff
Jeremy@NoLimit is offline
post #3 of 12 Old 07-19-2014, 05:14 PM Thread Starter
2006F350's Avatar
A guy in Indiana had it in his heated garage, he never even drove it in the rain.
Rich
2006F350 is offline
post #4 of 12 Old 07-19-2014, 08:33 PM
Wow kinda Looks like my setup! with a couple of stuff that I missing. My 05' will be getting done in a month.
08+ Trans pan and filter
Lift pump 6.4 pump
Build your own Regulated Return, but if you have the money.....EEEHH
Whats the Grand Total?????
bgraiders323 is offline
post #5 of 12 Old 07-20-2014, 02:05 PM Thread Starter
2006F350's Avatar
Lift pump 6.4 pump
I think I am going to go with a Andy Warren Transmission and save my stocker for backup if I can find a core.
Trying to avoid totaling
Rich
2006F350 is offline
post #6 of 12 Old 07-22-2014, 04:46 PM
Real Men of Genius
Super Diesel's Avatar
Quoted: 10 Post(s)
Feedback Score: 9 reviews
Maybe add a sump, O-ringed heads, maybe a delta line kit, and a Fumoto Valve! Other than that, your list looks great!
Chris | 2005 F-250 RCSB | "Ranger - Turbo Diesel V8"
CED Compounds - Conventionals - Supporting Mods
Super Diesel is offline
post #7 of 12 Old 07-23-2014, 05:14 AM
Quoted: 110 Post(s)
X'2 on the o-ringed heads. Couple hundred bucks for peace of mind.
Jeremy
2017 event info!!!!
2015 6.7 Platinum
Lots of NL stuff
H&S 369SXE
Spartan tuning
post #8 of 12 Old 09-04-2014, 07:32 AM Thread Starter
2006F350's Avatar
It's coming along nice, should have it back next Wednesday.
Casserly Full Force 190/75 Injectors
UCF Machine O-ring ported & polished heads
Mishimoto Intercooler
Fass Titanium Series 200
No Limit Cold Air Intake
Driven Diesel Regulated Return
BD Performance Exhaust Manifolds
Sinester Coolant Filter
Sinester Diesel Bypass Oil
ARP Studs
Sinester Turbo Y-Pipes (up) Stainless
Edge Insight CTS
Bullet Proof Diesel Billet Water Pump
SCT X4 Custom Tuner w/Innovative & Quick Tricks tunes
MBRP 4” Turbo Back Cool Duals Offroad T409 Stainless
Factory Oil Cooler
Sinister Intercooler Charge Pipe Kit
Billet Thermostat Housing
Sinister High Flow Intake Elbow
FICM Ficm Repair Ultra Service w/Atlas 40
MBRP 5" Dual Wall Exhaust Tips 304 Stainless
River City Diesel Billet Fuel Filter Cap
Driven Diesel Regulated Fuel Return Regulator Spring for FASS
Edge 98603 EAS Starter kit w/ EGT Cable for CS and CTS (expandable)
STC Fitting on the HPOP
ARP Stainless Exhaust Manifold Bolts M8-1.25X40mm
Exhaust Back Pressure Sensor
Turbo Oil Drain/Return Tube
Updated Turbo Feed Line
One Up Offroad Traction Bars Large Gussets 54"-84"
Hellwig Big Wig Rear Sway Bar
bgraiders323 likes this.
Rich
2006F350 is offline
post #9 of 12 Old 09-04-2014, 07:59 AM
peixinho's Avatar
Quoted: 191 Post(s)
ARP Studs
Edge Insight CTS
Factory Oil Cooler
Who did you go with for tunes?
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #10 of 12 Old 09-04-2014, 08:10 AM Thread Starter
2006F350's Avatar
I have some from Vivian and Eric (free ones from buying stuff) I also want to try some from gearhead too. Any recommendations?
Rich
2006F350 is offline
