sinister Y pipes- - Ford Powerstroke Diesel Forum
 13Likes
post #1 of 22 Old 07-19-2014, 06:21 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
sinister Y pipes-
Ive been looking at replacing my Y pipes. I finally got the serp belt to shut up so I can now hear what I beleive is a bellow leak. (Very high pitch upon wot acceleration)
So first question- is there any benefit to aftermarket over oem?
I see were sinister sells wrapped and ceramic coated. I know the wrap will hold in the heat but any other benifit?
I am now running a BPD upgraded egr cooler. I beleive I remember somewere that this is some sort of a issue with the aftermarket y pipes??????
Any other brands I should be looking at?
Thanks guys in advance. Jayson
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 22 Old 07-19-2014, 06:40 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I'm not sure anyone makes a set of upgraded pipes that has an upgraded EGR pipe too. Are you planning to delete the EGR cooler??
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 22 Old 07-19-2014, 07:46 AM
bondajb's Avatar
Just upgrade your bellows. I have an extra set done if you want 0 down time..
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #4 of 22 Old 07-19-2014, 08:27 AM
william_ace's Avatar
Quoted: 2 Post(s)
I have a set that Aaron made for me. AWESOME quality.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #5 of 22 Old 07-19-2014, 12:13 PM
snafu!'s Avatar
I have a set of AJB y pipes also, they fit perfect. Aaron had them built and shipped within 2-3 days.
I would stay away from MBRP y pipes, they have SS braid inside the bellows. It is known to expand and cut off exhaust flow.
bgraiders323 likes this.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #6 of 22 Old 07-19-2014, 12:58 PM
XL trash...
Merc82's Avatar
Quoted: 296 Post(s)
Just upgrade your bellows, like the others say. Most cost effective way. The Sinister piece is a long y pipe, replacing the egr up pipe with a solid piece. Oh and i agree... Aaron is offering a Damn good deal on his pipes..
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #7 of 22 Old 07-19-2014, 01:42 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Thanks for the feedback guys Ive been stuck up in the woods all day so I couldnt get back with you.
As to the egr I have the BPD upgraded egr so Im not worried about it. But I will be getting rid of the system next time Im in that far.
Aaron Iill be snding you a pm as soon as I get my reports in for the day!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 22 Old 07-19-2014, 06:31 PM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
well looks like I'm goin with the bondajb upgraded bellows. So new questions, when I get the pipes can I or should I try to wrap them? Would it be a good idea to look at possibly ceramic coating them?
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 22 Old 07-19-2014, 07:08 PM
Gadgetguru's Avatar
Quoted: 448 Post(s)
Garage
Cameron, I think we had this discussion in another thread about the MBRP y-pipe. They do have an interlock lining as shown in this photo of them before I installed them on my truck last week.
- Michael
2017 F350 Lariat DRW - SHE'S HERE!!! 29NOV16
- Click
for details
Sold 05OCT16 - 2006 F350 DRW - 175/Stock, UCF o-ringed heads, KC Stage 2 - Click
for details
'11 Ram 2500 Big Horn (Wife's), 6.7L Cummins - Click
for details
'13 XLR Hyperlite Toy Hauler 5er
Gadgetguru is offline
post #10 of 22 Old 07-19-2014, 07:09 PM
Just got done ceramic coating my stock pipes. All the info from cerakote looks promising and some info I found on wrapping pipes was not looking good. This is cerakote black velvet. It's an air dry ceramic good for 1800 degrees.
ID:	313594   Click image for larger version
kinnisoj likes this.
Diesel Equipment service manager lead technician
jpott62 is offline
