Will 175/stock nozzles require a upgraded fuel pump? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-18-2014, 06:56 PM Thread Starter
Dts327's Avatar
Thinking about buying warren 175/stock injectors to go with my new maxpower turbo, will the injectors require the use of a fuel system..if so what is recommended?
Dts327 is offline
post #2 of 15 Old 07-18-2014, 07:51 PM
No you dont, BUTTTTTT it is recomended.
You can do a Sump to 6.4 pump to 6.0 pump
Also would Recomend a Regulated Return, but thats just me some guys on here would say different.
bgraiders323 is offline
post #3 of 15 Old 07-18-2014, 08:26 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
No real need for a fuel system upgrade, unless you were to experience problems. Just about any upgrade would work nicely.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 15 Old 07-18-2014, 08:52 PM Thread Starter
Dts327's Avatar
Ok thanks guys
Dts327 is offline
post #5 of 15 Old 07-19-2014, 12:25 AM
snafu!'s Avatar
For the first 6 months I had a 7 psi drop with 175/75s then the hfcm started dropping pressure and it didn't stop. Normal driving was fine but wot dropped into the high 20s.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #6 of 15 Old 07-19-2014, 04:49 AM
XL trash...
Merc82's Avatar
Quoted: 333 Post(s)
Not entirely necessary with that set up, but wouldn't hurt especially if you plan on upgrading in the future, like maybe putting noozles on those injectors.
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #7 of 15 Old 07-19-2014, 06:03 AM
colonel angus's Avatar
Quoted: 2 Post(s)
You should get 30 nozzles and be done with it.
Still wont require a fuel system upgrade and the difference is HUGE especially when you add a larger turbo.
My .02
d
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #8 of 15 Old 07-19-2014, 02:51 PM Thread Starter
Dts327's Avatar
Would an airdog150 be a good move? I've never used any of their products but have heard mixed reviews...
2007 ccsb, Arp studs, stock HG, kc billet wheel powermax turbo, Banks intercooler kit, egr delete, stock downpipe followed by 4in straight, updated oil pipes & dummy plugs, stc fittings, SCT idp custom tunes, edge cts monitor, blue spring update, new oil cooler, elc coolant, airraid cold air intake, 35x12.5x18 Toyo mt's, rancho rs9000 shocks
Dts327 is offline
post #9 of 15 Old 07-20-2014, 09:55 AM
RJWTX's Avatar
A Fuel water separator is never a bad idea, keeps pure fuel (no air) and filters it better. You should be fine with an AirDog 100, but for about $30 more why not go with the 150? Also a good DIY regulated return would help keep stead constant pressure to the sticks. I went with the sinister Regulated return just to save from having to find all the pieces and AirDog 150gph.. just my $.02 and i agree 30% nozzles would be better.
2006 F350 CC LWB DRW 4x4 auto, AFE cold air intake, Sinister intake elbow, SCT live wire w/ gearhead tunes, 33s, ranch hands front and rear, Pyrometer, Sinister Regulated return, external oil and coolant finter, black diamond headgaskets, ARP studs, update kit, EGR delete, Diamond eye 4" turbo back to duals straight pipe w/ 6" tips, Air Dog 150gph, Topgun Customz 2" leveling kit, 175/stock sticks, KC 2 Turbo, 7.3 fan clutch conversion, Swamps 58v FICM w/ PHP eco tune... more to come
RJWTX is offline
post #10 of 15 Old 07-21-2014, 02:12 PM
dieseldan73's Avatar
I'm taking my 8 month old Airdog 150 off as I'm building a whole new custom fuel system. It will be for sale in a few days. Will come with a brand new water seperater and filters. Only has 1000 miles on it.
2005 Ford f350 CCSB King Ranch
MTW MadMax Turbo
Warren 155/30 injectors
EGR Delete
BPD Oil Cooler, FICM, Oil Bypass, Water pump
Flo-Pro 5" Exhaust, Cat Free, Muffler Free
All updated FORD Parts
ARP Studs With Factory Gaskets
PI Stallion Converter
TSD SPD. Thanks Chris,
Edge CTS monitoring
35x12.5x20 Dick Cepek FC-2 on Chrome Rockstars
4" Zone lift with Bilstien 5100's
dieseldan73 is offline
