Aftermarket Intercoolers - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 19 Old 07-17-2014, 08:55 PM Thread Starter
Quoted: 393 Post(s)
Lots of options out there, but not a lot of info. I'm having issues managing EGTs while towing through the mountains and foothills of BC and AB; an intercooler is part of the plan to get things right.
There really doesn't seem to be a side-by-side comparison of what does what best. even finding just the core dimensions can be difficult. I'm trying to narrow it down to an intercooler that will significantly lower EGTs without starving the radiator of cool air. Without knowing how well each intercooler cools and flows, as well as how much it disrupts & heats the airflow to the rad, it's made it difficult to shop.
I get no one here can do a side-side comparison, but who's running what, and what has it done for your EGTs, radiator effectiveness, power, etc. Cost is a factor I'll weigh later so I don't want to read how one or the other is the best bang for the buck... best cooling & flow vs. restricting the radiator is my biggest concern.
Thanks for your time.
2005 F-350 ext. cab long box, FX4
EDGE Insite CTS w/ fuel pres, EGT, and rear diff temp
Blue Spring
BCP High Idle Mod
DS Bypass Coolant Filter
Rotella ELC
Rotella T6 5w-40 Synthetic
EGR Cooler Delete
Bulletproof Oil Cooler, Oil Filter, & Amsoil Bypass Oil Filter
268 000km/167 500 miles as of Jan. 1 2015.
Canadian Mind is offline
post #2 of 19 Old 07-17-2014, 09:04 PM
Quoted: 15 Post(s)
I have the banks technicolor and like it. Fit is great but I cannot really say if it does anything for performance. Maybe lowers EGT by 100*.
lenzhotrod is offline
post #3 of 19 Old 07-17-2014, 09:12 PM Thread Starter
Quoted: 393 Post(s)
Did it affect your cooling system?
Blue Spring
BCP High Idle Mod
Rotella ELC
EGR Cooler Delete
post #4 of 19 Old 07-18-2014, 03:29 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I'm running a spearco intercooler and noticed very little when swapping to it. My cooling system was not affected. However, I would not recommend an IC right now if you're stock. You will see better gains in a billet wheel for your stock turbo. You could do a ported intake manifold too. Both of these options will give you lower EGTs than an intercooler will and costs less too.
Merc82 likes this.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #5 of 19 Old 07-18-2014, 05:06 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
With you truck being stock, I am a little surprised you are having heat issues. What temps are you seeing and under what parameters? Obviously you can run into issues with load, grade, altitude and speed (driving style), but you should be able to keep it in 5th at 50-60 mph using tow/haul to keep the RPM up and temps down going up grades.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 19 Old 07-18-2014, 05:46 AM Thread Starter
Quoted: 393 Post(s)
Most recent adventure - 17k combination, 55-65 mph, tow haul, 6-8% grades, 3.73s, 35 inch tires, 90f temps. Most of the time the temps stayed in the 1100-1250 range, but I don't like sitting in that bracket for up to 5 minutes at a time. Occasionally the temps spiked as high as 1350 halfway up the 7 and 8 % grades and I was forced to reduce my speed significcantly. One hill in particular I had to do 45 mph in a 75mph zone in order to keep the heat acceptable.
Previous mountain tow was in april running only a 14k combination. Ambient temp was around 0. Temps hit 1300 up a 7% grade at 70mph.
I am running a BPD oil cooler and do suffer stiction issues. But I can't imagine the oil cooler hampering my intercooler that much unless my intercooler is full of the CCV crud again.
Windrunner - This will be one of several upgrades including turbo, exhaust, FICM&PCM programming, etc.
Blue Spring
BCP High Idle Mod
Rotella ELC
EGR Cooler Delete
post #7 of 19 Old 07-18-2014, 08:30 AM
borsky4's Avatar
changing your gear ratio will help a lot run 4:10-4:30's with your 35's
2006 CC SB, SRW, Barder stg #2, Ported manifold, Warren 190 30's, banks CAC, SCT Tuned by/IDP, IDP ficm tunes, nadp trans, fluidampr, FASS LP, Driven RR, edge insight, HPODS, BD ex manifolds, HD y pipe all ceramic coated & wrapped, UCF O-ringed heads with arp's, Colt stg 1 cam with RCD springs and tubes,
6" lift/trac bars, 37's 4:30 gears, Future mods: non VGT T4 64mm BASB
borsky4 is offline
post #8 of 19 Old 07-18-2014, 01:04 PM
bootcamp's Avatar
Quoted: 4 Post(s)
do the 4:30's and skip the 4:10's, I did the 4:10's on it really wasn't worth the money in the end, If your gone a tow with it, do the 4:30 and that should help a lot with egts.
USMC
05 F250 6" LIFT, Custom Fuel System, RR KIT, Fuel, TRANS, OIL, PYROMETER GAUGES, Fluid Damper, TSD & IDP Tunes, HellmaNs Sump, 4.10 Gears, ARP +625,Factory Gaskets,Apex ported manifold, MBRP EXHAUST , Atlas 40, Warren 175/75 injectors, 68mm Pmax w/ Batmowheel, BPD rad, BPD water pump, Sinister Y Pipe,Alradco Intercooler, O-Ring Heads and the list goes on.
bootcamp is offline
post #9 of 19 Old 07-18-2014, 01:10 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
What altitude are you running at? Here at 6000' plus I can get 1400* just getting on the highway.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 19 Old 07-18-2014, 03:01 PM
Quoted: 47 Post(s)
Calgary is about 3,600' and it only gets higher as you move into the mountains towards BC, so he will see varying terrain about as you would see in mid-southern Colorado & New Mexico. The foothills on the west side are considerably lower and the time at higher altitude is less than in Colorado.
Frank
Working for Toys
