BPD HD cooler and 155s towing review - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 23 Old 07-17-2014, 06:51 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
I'm in flagstaff AZ, Vegas tomorrow final destination, started in WA DC. Did the same trip with same load (reverse direction) with OEM fan, injectors, and BPD standard cooler exactly 2 years ago. The load is my 40' toyhauler that weighs 14 empty, with a 3200 lb car, and 2500 lbs of household items and tools. Ill weigh it tomorrow but I've towed the load many times its right at 30k. On my trip two years ago I has no issues with EGTs but did run high EOTs. Seen 240ish a good bit and got up to 265 on a long hard pull. Over the two years in DC I did some mods to try to fix this for return trip. I added 7.3 fan (BPD adapter) BPDs HD (taller) cooler and a mesh grille to promote higher airflow. I also added 155/30s.
I have now pulled across near the entire country and can say the BPD HD coolers are the end all be all, period. Same sections I flirted with 250 I was running 220. Highest EOT seen yet is 228 and that's long grades at 50 mph where it's toped out, the cooler is amazing. Combined with my 7.3 fan and mesh grille, overheating is a thing of the past. It's such a huge differance then last time I'm sure I could of kept the OEM Fan and grille and would of been fine. Thank you Ken and BPD my overheating issues are behind me.
Now the 155/30s, mixed feelings. In running a "heavy tow tune" with fuel pulled from the 155s for this heavy load. DC all the way thru TX no problem worked great, but in NM the elevation across the entire state is 6k, for whatever reason this is not good for the 155s, I have to monitor them and in OD could rocket past 1400 if I tried. I'm babying the throttle to barely squeak out 65mph at 1200 EGT (for hours). Just checked motor tonight and didn't melt anything, so I've proven you can run right at 1200 for two hours straight. I would just drive to keep pedal pressure to maintain 1200 and this got m 65 mph give or take. The speed limit is 75 but I can't get there. Before NM and the high elevations, 1100 EGT would keep me at 70mph all day long. So I have mixed feelings, yes you can tow but I feel I could of had more power on stock sticks in NM. Ill drop out of 6-7000 feet tomorrow and leave these worries behind me, but you guys that live at altitude, I'd recommend against.
I can't say enough good things about the BPD products, my truck runs like a champ and once again gets my Fam and toys across the country.
Evil Eye and 6.0newb! like this.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
The Following 4 Users Say Thank You to jetjock15 For This Useful Post:
kinnisoj (07-18-2014), Lilpooh (07-18-2014), rabpearson (07-17-2014), rr06psd (07-18-2014)
post #2 of 23 Old 07-17-2014, 07:00 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Nice, glad to see your high EOT temp problem is solved. I've also towed at 1200*f (egt) for several hours and my truck is still running strong as well. Makes me wonder if I should upgrade to the HD oil cooler as well.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 23 Old 07-17-2014, 07:17 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
I should add that in all the states before NM at altitudes 3k and below the 155s were great, completely controllable and noticeably more pulling power then I've ever had.
post #4 of 23 Old 07-17-2014, 07:25 PM
Quoted: 8 Post(s)
Think a stage 2 turbo would've made a difference?
Sent from AutoGuide.com App
2005 F250 FX4 6.0 PowerStroke, Dashboss, Swamps 58V FICM, PHP Atlas 40 tune, Tony Wildman Extreme Tune, IPR Coolant filter, ELC Coolant, EGR....nevermind, updated stc, more to come!
Babyboy70363 is offline
post #5 of 23 Old 07-17-2014, 07:35 PM Thread Starter
jetjock15's Avatar
Quoted: 113 Post(s)
I don't think so, I have the slightly bigger wheels in the S1 and I don't think bigger turbo would have made any difference. It's hard to describe but at low elevations, if I hit a grade I could give it throttle and get 11-1200 EGT and 30-33 boost, but in NM at 6k if I give it throttle it would be 1400 EGT at 30 psi so I have to back off, and then I'm sitting at 15 psi boost and 1200-1250 EGT, I can't boost higher cause I can't push the throttle more you know.
post #6 of 23 Old 07-17-2014, 07:53 PM
snobdds's Avatar
Quoted: 10 Post(s)
Welcome to my world. I'm at 8000 feet and honestly, stock fueling is best. The air density here is low and extra fuel does no good. Just not enough molecules to cram into the combustion chamber as there are at lower elevations. Even bigger turbos are of minimal use, but they do help with EGT's .
snobdds is offline
post #7 of 23 Old 07-17-2014, 09:18 PM
Quoted: 8 Post(s)
Got it! Man fortunately I don't have to worry about this in South Louisiana! However, I'm always interested to know what to expect should the road bring me that way! Appreciate the info!
post #8 of 23 Old 07-17-2014, 09:44 PM
great thread thanks for the insight! im glad you got your issued solve, you always seem to push the truck to its limit! Keep us posted on any other issues or lack of and happy truckin
mannythechamp is offline
post #9 of 23 Old 07-18-2014, 04:58 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
This answer's some of my questions about my egt's. Poor girl just dosnt have the air to work with.
Im bummed that I dont have the BPD heavy duty oil cooler. It is and was a let down when I found out that I missed getting one by a month or so. If I would of know'n I would of waited.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #10 of 23 Old 07-18-2014, 07:07 AM
peixinho's Avatar
Quoted: 217 Post(s)
Thanks for the great write up. Glad you are liking your new setup!
As others have said... when you are up that high in altitude the air is thinner and will cause your turbo to run less efficiently. It changes the pressure ratio that the turbo operates at which in most cases will push you out of the efficiency islands that you desire and you end up blowing hotter air, which in result will raise egts. Depending on what RPMS you were having the problem... a slightly bigger or slightly smaller turbo might help out your situation a little bit.
About the 155/30 vs 155/stock... 155/30 is a very weird injector size to me. I don't mean to sound negative... but I don't like it. You don't need a larger nozzle to dump 155cc of fuel... even on a conservative tune without crazy timing and pulse width. All you are doing with 30% nozzles on 155cc injectors is dumping fuel at a lower atomization which causes a loss in efficiency and can raise egts and lower power. It is not simply about dumping too much fuel that causes your egt issues. It is actually has much more to do with the fact that you are putting out the same fuel at a much lower efficiency, which may causes you to have to dump a little bit more fuel to maintain the same power and speed.
For example cruising with a heavy load you might see these numbers to dump the same amount of fuel:
155/stock = 1.1ms of pluse width and 1.9v ICP
155/30 = .9ms of pulse width and 1.5v ICP
So basically the timing is well within desired parameters... BUT... you have to sacrifice ICP to dump the same amount of fuel with the larger nozzles. This leads to lower injection pressure, which leads to less efficiency, which causes power to go down, which might cause you to have to add slightly more fuel to keep the same speed, which can lead to much higher egts.
Just curious if you data logged any of the trip?
At what RPMS were you cruising when you were struggling with temps?
Sound like your headgaskets did great?
RollinEarly99 likes this.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
The Following User Says Thank You to peixinho For This Useful Post:
RollinEarly99 (07-21-2014)
