Fuel System Build Parts - Ford Powerstroke Diesel Forum
 3Likes
  • 3 Post By bootcamp
post #1 of 4 Old 07-16-2014, 01:53 PM Thread Starter
bootcamp's Avatar
Quoted: 7 Post(s)
I have thrown a list of parts together from various places and what it would require to build your own fuel system from the tank to the heads and back to the tank. Their are several vendors that sale the RR kits and they are all good kits. Also the same thing with the tank sumps, I used Hellmans sump myself, but there are several other vendors that also sale these sumps. All of the fittings can be bought from Summit, Jegs, Earls, AnPlumbing, etc.
I have included the fittings needed for the secondary fuel bowl if you decide to keep it. The pump can be bought from several vendors on the forums.
If I got a part number crossed up or an incorrect link, dont beat me up bad over, its pretty hard to put this stuff together when you a touch of ADHD & Dyslexia going at the same time.
They're several different filter set ups that can be use, i just decided to go with what what being posted on some of the other fuel system threads.
Part number
Fuelab 41401 (1000hp) Fuel Pump
41401-2
1 each
Baldwin FB1311 Fuel/Water Filter Separator Base
FB1311
1 each
Baldwin FB1311 Fuel Filters | Filters | EverythingTruckParts.com
Baldwin BF7633 Fuel Filter
BF7633
1each
Baldwin BF7633 Fuel Filters | Filters | EverythingTruckParts.com
Baldwin BF1252 Primary Fuel/Water Separator Spin-on Filter
BF1252
1 each
Baldwin BF1252 Fuel Filters | Filters | EverythingTruckParts.com
ANOTUFF 10AN SWVL TO PORT
361-AT985210
2 each
Earl's AT985210 Earl's Ano-Tuff AN Male to AN Male Swivel Port Union Fittings - Free Shipping on All Orders @ JEGS
6AN X3/8SAE FEM LT1 BLUE
799-640850
?Each
Russell 640850 Russell Push-On EFI Fuel Line Adapters For OEM Hard Line - Free Shipping on All Orders @ JEGS
Metric Thread: 14mm X 1.50 AN Thread: -8
871408
1 each
Search Results | 871410
Metric Thread: 14mm X 1.50 AN Thread: -10
871410
1 each
Hose Size: -10
410010
10 ft
AN Perform-O-Flex Hose | ANplumbing.com
Hose Size: -8
410008
10 ft
Search Results | 410008
Straight: -10
800110
2 each
Search Results | 800110
Straight: -8
800108
8 Each
Search Results | 800108
AN Male: -10 Port Thread: -10 O-Ring
985010
2
Search Results | 985010
16mm x 1.5 Metric -8an Thread Male To A.N. Male Adapter W/ Crush
871608
1
AN Metric Adapters | ANplumbing.com
12MMx1.5 90 Deg. METRIC Male To Male A.N. Swivel. Black Hard An
AT949092
4
Search Results | 949091
Beans Diesel Performance Fuel Tank Sump
sku:BDPSTS11A
1
Beans Diesel Sump
Before install on truck
After install on truck
Regulated return kit of your choice
1
Driven Diesel 6.0L Regulated Return Kit
Driven Diesel Regulated Return Fuel System Kit
USMC
05 F250 6" LIFT, Custom Fuel System, RR KIT, Fuel, TRANS, OIL, PYROMETER GAUGES, Fluid Damper, TSD & IDP Tunes, HellmaNs Sump, 4.10 Gears, ARP +625,Factory Gaskets,Apex ported manifold, MBRP EXHAUST , Atlas 40, Warren 175/75 injectors, 68mm Pmax w/ Batmowheel, BPD rad, BPD water pump, Sinister Y Pipe,Alradco Intercooler, O-Ring Heads and the list goes on.
bootcamp is offline
The Following User Says Thank You to bootcamp For This Useful Post:
Lilpooh (07-17-2014)
post #2 of 4 Old 07-17-2014, 08:15 AM
dieseldan73's Avatar
Nice write up. I just opened up my box of parts from Jegs 20 minutes ago. Hopefully will be starting mine tomorrow. I like the picture of my fuel pump and filter set up in your PDF!
2005 Ford f350 CCSB King Ranch
MTW MadMax Turbo
Warren 155/30 injectors
EGR Delete
BPD Oil Cooler, FICM, Oil Bypass, Water pump
Flo-Pro 5" Exhaust, Cat Free, Muffler Free
All updated FORD Parts
ARP Studs With Factory Gaskets
PI Stallion Converter
TSD SPD. Thanks Chris,
Edge CTS monitoring
35x12.5x20 Dick Cepek FC-2 on Chrome Rockstars
4" Zone lift with Bilstien 5100's
dieseldan73 is offline
The Following User Says Thank You to dieseldan73 For This Useful Post:
bootcamp (07-17-2014)
post #3 of 4 Old 07-17-2014, 09:42 AM Thread Starter
bootcamp's Avatar
Quoted: 7 Post(s)
I had to use someones, cause I don't have one of my own yet, the only thing I haven't order yet is the pump.
USMC
bootcamp is offline
post #4 of 4 Old 07-17-2014, 10:45 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
NICE parts list!!
"Rich is really good with knobs, his soft touch and attention to detail are like no other."-Portcity_gt
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
The Following User Says Thank You to Lilpooh For This Useful Post:
