VISION DIESEL PERFORMANCE aluminum degas bottles now available!! - Ford Powerstroke Diesel Forum
 22Likes
post #1 of 62 Old 07-15-2014, 05:31 PM Thread Starter
MWilbur516's Avatar
Ok guys, we've got aluminum degas bottles for the 6.0 now. We offer them with a filler neck that will accept your stock degas cap or we can build them with an aftermarket 16# cap, your choice. There is a sight gauge on drivers side to watch your coolant level. They all come with 2 - 1/4NPT bungs. This allows for use of the stock radiator overflow line as well as a coolant filter return line, without the need to "T" into the stock line. We also put a 3/8NPT bung in for use with the stock return line from the intake manifold or you have a direct route for your delta line kit without the need to "T" into a larger return line on the firewall. Not having to cut into stock lines gives a cleaner look and less spots for leaks.
The bottles come with bungs welded in place, but the customer supplies whatever fittings he/she needs or wants. These can be sourced at any local hardware store.
The introductory price will be $299 plus shipping. We can also powder coat the bottles in any color the customer would like for an extra charge. I'll powder coat them black (gloss, flat or textured) for $40 extra. Any other colors will be priced at the time the order is placed.
Sent from AutoGuide.com App
Matt | 2006 F250 XL FX4 6.0L 485RWHP and 968RWlbs-ft
Vision Diesel Performance503-487-6074
BULLET PROOF DIESEL 1-888-967-6653
TWISTED TRANSMISSION Contact me for a quote on a trans with the best warranty in the business.
MWilbur516 is offline
post #2 of 62 Old 07-15-2014, 09:49 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Looks good Matt. Any install pics? Are these pressure tested?
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #3 of 62 Old 07-16-2014, 02:22 AM
snafu!'s Avatar
Looks good I would like to see how it mounts also.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #4 of 62 Old 07-16-2014, 03:27 AM Thread Starter
MWilbur516's Avatar
They are pressure tested.
ODAWG714 likes this.
post #5 of 62 Old 07-16-2014, 03:58 AM Thread Starter
MWilbur516's Avatar
Here's an installed pic. This is the initial design and we've flattened the front off so it doesn't come to a point. The mounting is the same though. It uses the stock mounts and location. Basically a drop in install. This is our fabricators truck and you can see how he returned his coolant filter line and how he returned his coolant from the oil cooler (delta line kit) directly to the degas.
post #6 of 62 Old 07-16-2014, 06:10 AM
strokin6L's Avatar
Quoted: 3 Post(s)
Looks awesome matt! How much will these be?
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #7 of 62 Old 07-16-2014, 06:17 AM
Chatham036's Avatar
Quoted: 135 Post(s)
Just an idea, why dont you guys fabricate the bottom to fit farther back towards the firewall to increase the engine's accessibility on the driver's side?
If you look at the image, basically remove the front portion where the angles are then move the fill point back closer to the firewall.
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #8 of 62 Old 07-16-2014, 06:18 AM
Chatham036's Avatar
Quoted: 135 Post(s)
Here is text pulled from his original post
post #9 of 62 Old 07-16-2014, 06:42 AM
scparrish's Avatar
Quoted: 85 Post(s)
Feedback Score: 3 reviews
everything is awesome about this until you are working on a hot truck, but who cares about burns that thing seriously looks awesome.
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Turbo, PMF, S&B, Mishimoto rad/ic, 08 axle swap
scparrish is offline
post #10 of 62 Old 07-16-2014, 07:35 AM Thread Starter
MWilbur516's Avatar
If you look at the new design. We did just that. That installed pic is the initial design that we revised.
knuckledragger5 likes this.
