speed brake versus exhaust brake - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-14-2014, 07:28 PM Thread Starter
I had a Banks exhaust brake on my 2001 Powerstroke. Now I'm looking into putting one on my "07 Powerstroke. My performance shop suggested the banks speed brake. I visited the banks website, read and watched the video, and I still don't understand the difference. Can someone explain the difference please.
plumbob is offline
post #2 of 5 Old 07-15-2014, 03:16 AM
bondajb's Avatar
What is your need for an exhaust brake.. with a custom tune the turbo can be manipulated to behave similar. .
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
The Following User Says Thank You to bondajb For This Useful Post:
plumbob (07-15-2014)
post #3 of 5 Old 07-15-2014, 05:15 AM Thread Starter
I tow a 36' toy box. I've never been happy with the brakes on it so that is why I like an exhaust brake
plumbob is offline
post #4 of 5 Old 07-15-2014, 05:45 AM
crash&burn's Avatar
Why not get a custom tow tune with the "Jake brake" added to the tune, or upgrade the braking system bigger calipers and rotors.
From what I have heard an exhaust brake may work for helping you stop but without upgrading the exhaust valves and and exhaust valve springs can result in failure of those using an exhaust brake.
A little easier and probably cheaper to put a bigger caliper/rotor kit on the truck.
Shawn
2004 CC F350 - 4-5" exhaust no cat - CTS Insight with turbo timer and Egt's - EGR Delete - K&N - Coolant Filter
SCT with Custom Tunes - MTW MadMax - 190/Stock - PTP Solenoid - Blue Spring - A few mystery switches
crash&burn is offline
post #5 of 5 Old 07-15-2014, 05:48 AM
bondajb's Avatar
The jake brake tunes work well.. I really like the files Vivian from Quick Tricks writes for me!!
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
bondajb is offline
