Boost numbers after tuning - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-14-2014, 06:19 PM Thread Starter
Powerstroke92's Avatar
Quoted: 5 Post(s)
Hey guys I just got my truck "bulletproofed" and installed Vivian's tow, looney, and looney wild tunes. This thing smokes like a train on both looney and looney wild to the point that she sent me a reduced fuel version that she gives to guys with bigger turbos. After talking with Vivian I have her stumped. Stock I make approx.17psi of boost, tow 20psi, looney 23psi, looney wild about 26psi. Should I be seeing the same boost numbers for each tune or is it normal to see more boost the hotter the tune. Also wot on looney wild is only good for about 200yd before I hit 1400egt I assume this is due to not enough at and stock exhaust. Asides from the smoke and egt this thing feels like a rocket ship.
2004 F350 6.0 egr delete, arp studs, sinister coolant filter, 03 turbo, sct "bama" with looney tunes by Vivian
SOLD - 2003 f350 6.0 with 08 motor
5in diamond eye turbo back
SOLD- 1999 f350 7.3 with zf6
Powerstroke92 is offline
post #2 of 8 Old 07-15-2014, 02:46 AM
XL trash...
Merc82's Avatar
Quoted: 334 Post(s)
Have you checked for any boost leaks?
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #3 of 8 Old 07-15-2014, 05:04 AM Thread Starter
Quoted: 5 Post(s)
I bought the supplies to make a boost leak detector but haven't had time to check. I believe I have an 03 turbo so the 24psi on looney wild should be about normal right? I'm just confused why on the lower tunes I'm seeing a lot lower boost
post #4 of 8 Old 07-15-2014, 08:35 AM
XL trash...
Merc82's Avatar
Quoted: 334 Post(s)
I'm no expert...but I heard tuners have ways of manipulating the map sensor parameters. Your boost may be higher than what you see on the dash. The only way to truely know is to plumb in a mechanical fuel gauge.
Merc82 is offline
post #5 of 8 Old 07-15-2014, 12:27 PM Thread Starter
Quoted: 5 Post(s)
Also if the truck sits overnight it will let out a puff of black smoke when it first starts
post #6 of 8 Old 07-15-2014, 02:23 PM
XL trash...
Merc82's Avatar
Quoted: 334 Post(s)
I get that too.
Merc82 is offline
post #7 of 8 Old 07-15-2014, 02:25 PM
XL trash...
Merc82's Avatar
Quoted: 334 Post(s)
I don't run Looney anymore, it was very smokey and too "lighswitchey".
Merc82 is offline
post #8 of 8 Old 07-15-2014, 02:33 PM
Gadgetguru's Avatar
Quoted: 448 Post(s)
Garage
Normal for a diesel IMO.
- Michael
2017 F350 Lariat DRW - SHE'S HERE!!! 29NOV16
- Click
for details
Sold 05OCT16 - 2006 F350 DRW - 175/Stock, UCF o-ringed heads, KC Stage 2 - Click
for details
'11 Ram 2500 Big Horn (Wife's), 6.7L Cummins - Click
for details
'13 XLR Hyperlite Toy Hauler 5er
Gadgetguru is offline
