Headgasket Job - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By dnf12908
post #1 of 9 Old 07-13-2014, 12:08 PM Thread Starter
madmancm's Avatar
Quoted: 2 Post(s)
Headgasket Job
I'm looking at doing a head stud job on my 6.0 and had few questions.
1. I've been told to go with Ford OEM Headgaskets, but it seems like the price is pretty damn high for Ford OEM because they come as a kit with the gaskets and head bolts. Does anyone know of anywhere I can buy just the Ford Headgaskets and pay a little less?
2. I'd like to get all the parts in advance, but the Ford dealership said they couldn't tell me whether I had 18 or 20mm dowels. My truck has a build date of 3/06 so they said it could be either. Is there anyway to tell without pulling apart the engine?
3. If I were to go to an International dealership and get the head gaskets, would they be a direct fit?
Thanks in advance
madmancm is offline
post #2 of 9 Old 07-13-2014, 02:39 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
IIRC (and maybe confirm with a Ford tech on here but) trucks built after 1/2006 have 20mm dowels.
I personally would recommend just paying the premium for OEM HGs and throwing the bolts away.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 9 Old 07-13-2014, 03:12 PM
dnf12908's Avatar
Quoted: 25 Post(s)
I believe the kit comes with both the stepped and straight dowels anyway.
Gadgetguru likes this.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Insight CS monitor
Harley headlights
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
post #4 of 9 Old 07-13-2014, 04:51 PM
Gadgetguru's Avatar
Quoted: 432 Post(s)
Garage
Sho nuff. What he ^^^ said.
Just order up the gaskets from AutoNation and be done with it. Some places will sell you just the gaskets but I don't think they are any better on price.
- Michael
2017 F350 Lariat DRW - SHE'S HERE!!! 29NOV16
- Click
for details
Sold 05OCT16 - 2006 F350 DRW - 175/Stock, UCF o-ringed heads, KC Stage 2 - Click
for details
'11 Ram 2500 Big Horn (Wife's), 6.7L Cummins - Click
for details
'13 XLR Hyperlite Toy Hauler 5er
Gadgetguru is offline
post #5 of 9 Old 07-13-2014, 08:59 PM
borsky4's Avatar
Save your money buy black diamond mls gaskets. The only reason people all think the need Oem is because for a while guys thought that the black onyx gasket was the cure all and it wasn't so everyone went went back to Oem and that's how this mentality started.
IMO the black diamond mls gaskets are every bit as good as Oem only difference is the silicone color. Made at the same factory. Dcf engines offers a 5 yr warranty on there reman engines and they run the black diamond gaskets with arp studs.
That's what I have in mine too. Your money so you decide
2006 CC SB, SRW, Barder stg #2, Ported manifold, Warren 190 30's, banks CAC, SCT Tuned by/IDP, IDP ficm tunes, nadp trans, fluidampr, FASS LP, Driven RR, edge insight, HPODS, BD ex manifolds, HD y pipe all ceramic coated & wrapped, UCF O-ringed heads with arp's, Colt stg 1 cam with RCD springs and tubes,
6" lift/trac bars, 37's 4:30 gears, Future mods: non VGT T4 64mm BASB
borsky4 is offline
post #6 of 9 Old 07-14-2014, 04:50 AM
Borsky makes a good point. I wonder if the black onyx gaskets are really any better or worse than OEM.
I have read of PLENTY of scenarios of people needing new HGs after studs, regardless of what HGs used.
Ideally head studs and new HG's should be the permanent "bulletproof" fix. BUT, we all know that they still arent perfect, sometimes due to warped heads, etc. Perhaps we originally were blaming the failures on Black Onyx gaskets when in reality, its machine work, etc to blame.
Stlavsa is offline
post #7 of 9 Old 07-14-2014, 04:51 AM
XL trash...
Merc82's Avatar
Quoted: 268 Post(s)
The OEM also come with standpipes... Which, even if already updated, I would change out anyway just to have ones with fresh orings on them back in there.
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #8 of 9 Old 07-14-2014, 05:36 AM
borsky4's Avatar
Just to be clear make sure what you get is a multi layer steel gasket. Not a graphite type gasket. The graphite ones are responsible for the bad reputation
borsky4 is offline
post #9 of 9 Old 07-15-2014, 02:58 AM
Jeremy@NoLimit's Avatar
Quoted: 110 Post(s)
I'm running the Black Diamond as we'll. No issues yet. Just pulled 12k with 35" tires back from the north Georgia mountains without a single issue. They look identical to OEM's except the sealant color.
Do no confuse Black Diamond with Black Onyx. They don't make the Black Onyx anymore
Jeremy
2017 event info!!!!
-Jeremy- No Limit Fab
Sp@rtan, SCT, GH, PIP, H&S
Orders-1 800 581 8986
My direct line (706)549-5355
".org5" coupon code/discount for powerstroke.org members!
2015 6.7 Platinum
Lots of NL stuff
H&S 369SXE
Spartan tuning
2006 Shorty in progress
Lots of fuel, turba and NL stuff
Jeremy@NoLimit is offline
