Anyone else have higher trans temps with 1800 stall converter? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 45 Old 07-10-2014, 10:30 AM Thread Starter
Gearhead2012's Avatar
Quoted: 2 Post(s)
I'm on transmission rebuild #3, and the 3rd converter, it's a PI, precision industries, supposedly 1800 rpm stall. I've heard stock is 1700, I've also heard 1800...I know PI offers the 1800 which they say is their best seller, and they offer a 1700 stall for those that do a lot of towing, and then of course several higher stall options for non Vgt turbos/track.
Anyway, my trans temps creep up to 190-200+ when the Tc isn't locked, I can't tow anything in stop and go traffic, it gets too hot. In fact, just idling in drive or reverse, the trans temps climb up, put it in park or neutral and they come back down. While driving, when the Tc goes into lock up, it cools off too. I've been told I need to have tunes written to have the Tc locked all the time, but I don't feel that's right at all.
I'm just looking for other peoples feedback and their experience with aftermarket converters. First converter used with the first rebuild 6-7 months ago was a PATC, it was waaay looser and waaaay hotter than it is now, so it's kinda better, but not 'right'. The trans still feels 'looser' than it should, I've been told the high temp and looseness is because of the slightly higher stall converter, but converter company says no. Thanks for your input.
2005 F-250 Harley Davidson Edition
6.0 cylinder heads and custom engine building available
Under construction
Warren 205/75 Injectors
Icon 4 Link, 37" Nitto's
SSBC 6 piston calipers
Yukon 4.30's, Detroit Locker
Machining the 6.0:
Gearhead2012 is offline
post #2 of 45 Old 07-10-2014, 11:18 AM
bondajb's Avatar
1800 stall.. pulling my rolling condo... I saw 202 deg max trans temp pulling on the dirt at 35 mph.. Ambient was 95+
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #3 of 45 Old 07-10-2014, 11:51 AM Thread Starter
Quoted: 2 Post(s)
How long were you doing 35? If I drive for more than about 20 minutes in stop and go, city driving below Tc lock up speeds, it gets to 200*, unloaded. Towing a light light load at 35-40 mph (less than 5k lbs) trans temp got to 215ish or so, and puked fluid onto the exhaust, cars behind me that stopped said they saw a huge fireball under the truck, I guess where it caught fire. Perhaps it was overfilled from where the builder topped it off when he had the truck.
Under construction
Machining the 6.0:
post #4 of 45 Old 07-10-2014, 12:11 PM
strokin6L's Avatar
Quoted: 3 Post(s)
Those temps seem way to high for not pulling anything. The hottest I've seen mine in mixed driving during the day was 165* on a 90* day. Do you have a deep pan? Also...I only have the stock converter...but I don't see why the temps would be higher with an aftermarket converter vs the factory one. I would think they would be the same depending on stall I would think.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #5 of 45 Old 07-10-2014, 12:19 PM
snafu!'s Avatar
Sounds like the coolers are plugged or the pump in the trans is going out. Those temps are insane. I see about 160 consistently with a 1600 stall.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #6 of 45 Old 07-10-2014, 12:25 PM Thread Starter
Quoted: 2 Post(s)
Cooler has been flushed several times, thoroughly, and the temps cool right back down to 155-165 when the Tc locks. Andy put a new pump and a new PI converter in it when he took the truck back up to PA to fix it, again. I might replace the cooler just to eliminate that as an option. And yeah, Chris, it's a Maghytec pan, holds 8 additional qts, which makes it that much more surprising to me that it gets so hot so quick.
Under construction
Machining the 6.0:
post #7 of 45 Old 07-10-2014, 12:32 PM
strokin6L's Avatar
Quoted: 3 Post(s)
Yeah I run a mag hy-tech pan also. Those temps are just rediculous tho!
post #8 of 45 Old 07-10-2014, 12:43 PM
scparrish's Avatar
Quoted: 84 Post(s)
Feedback Score: 3 reviews
I see 170-180 unloaded with 97+ oat.
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Turbo, PMF, S&B, Mishimoto rad/ic, 08 axle swap
scparrish is offline
post #9 of 45 Old 07-10-2014, 01:17 PM
Diesel996's Avatar
I have a stock trans w/ a Mag-Hytec pan. I have never seen higher than 157 degrees.
Edit: But I don't tow much either.
Brian
'06 F-250 SD Harley Davidson CCSB (STOLEN)
8" Double Shock Hoop Lift - Pro Comp / Fox
37" Toyyo MT's
175/stock Warren Injectors
MTW Stage II Turbo
WPE Ported Intake Manifold
EGR Cooler Welded
Line-X Extra
and more...
Diesel996 is offline
post #10 of 45 Old 07-10-2014, 01:18 PM
peixinho's Avatar
Quoted: 192 Post(s)
I wonder if there is any way to check to see how well the cooler is working??? I know with some things that if it is clogged with metal shards then it does not matter how many times you flush it... you gotta replace it. Kinda like the a/c condenser, oil cooler, and even radiators. Sometimes they are just too far gone.
My vote would be that the tranny cooler is shot/clogged and/or there is some sort of restriction in the tranny cooler lines
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
