Isspro ev2 fuel pressure ?'s - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-10-2014, 07:38 AM Thread Starter
So I finally got around to installing my isspro ev2 fuel pressure gauge. I'm not to happy with how everything went. First my test port adaptor fitting I got from glow shift leaked diesel soon as I put it on. Should have not gone cheap on the adaptor but how bad could it be? It's just a simple fitting?? So I finally get the gauge in and working and not leaking. Now idling or lightly cruising my fuel pressure is bouncing from 65-68-70-65-68 ect. It's only steady if I stay on it. I'm wondering if I have a bad gauge or sending unit or fuel pump? I changed filters the day I put the gauge in and already did the blue spring on the regulator. Anyone have any ideas?
6ohslow is offline
post #2 of 12 Old 07-10-2014, 05:58 PM
Quoted: 8 Post(s)
Mine used to bounce a lot until I went regulated. Now steady as a rock. 55 PSI.
06Mike is offline
post #3 of 12 Old 07-11-2014, 04:43 AM
KingStroker's Avatar
Quoted: 3 Post(s)
I'm pretty sure they all bounce. My glowshift does the same thing...at first I thought it was the gauge, but near as I can tell they all do it at times. Mine is worst when the engine bogs with the TC locked it'll jump a good bit. At idle or cruising it sits 59-60 and hardly ever moves.
Brian - 2005 F250 CC SB King Ranch
35" Nitto's 20" American Racing Wheels
SCT tuned by Vivian, BPD EGR Delete, ARP Head Studs, OEM Gaskets, 4" MBRP Turbo Back Exhaust, Edge Insight, Zoodad Mod., Fog Light Mod., New Y-pipe, 08 tail lights, 08 Rear Diff Cover, Sinister coolant filter, Zerex ELC, Blue Spring
Future mods:
Guages
08 Rear Bumper and Tailgate
Possibly 08 Mirrors? Can't decide...
KingStroker is offline
post #4 of 12 Old 07-11-2014, 06:54 AM
Live with the bounce or put a restrictor between the port and sender, it acts like a snubber. Mine does it but all I care about is that it reads above 45 psi.
03 F-250 6.0 Black/Gold Lariat CC SB FX4
jsm180 is offline
post #5 of 12 Old 07-11-2014, 08:52 AM Thread Starter
Ok thanks guys I was worried I went through all this and it bounces! Feel a little bit better now! Anyone have the Strictly Diesel relocation line? I heard it fits then some say it don't can't find a solid answer. Thanks again!
6ohslow is offline
post #6 of 12 Old 07-15-2014, 08:17 AM
COAL FIRED's Avatar
I run the EV 2 gauges with Stictly Diesel's relocation line it works good although I had to grind the fitting just a little.My fuel gauge bounced with my stock setup and even after I installed my regulated return.Then about 2 weeks ago while on vacation the sensor failed it was just over a year old and they warrentied it with a new updated sensor I haven't installed it yet but hoping it is a little more stable.
2006 f250 ccsb,sct tunes by IDP & gearhead ,studded&deleted,4"magniflow turbo back,coolant filter,ccv reroute,isspro ev2 gauges&scangauge,accufab elbow, stc fitting dummy plugs&stand pipes,sinister diesel reg return,powermax MTW sp billet wheel,S&B intake,AFE ic pipe
Matt
COAL FIRED is offline
post #7 of 12 Old 07-15-2014, 10:11 AM
peixinho's Avatar
Quoted: 174 Post(s)
What do you mean by that? You just added a regulated return?
Mine bounces also and I have been meaning to find a good fix for it
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #8 of 12 Old 07-15-2014, 09:30 PM
Quoted: 8 Post(s)
on my 2nd round of upgrades i did DD's regulated return along with other goodies. I did it despite advise not to. I believe the regulator helps isolate the pulses that cause the gauge to fluctuate. With all my mods the truck runs fantastic. Pulling the toyhauler or cruising the I40 to the river.
06Mike is offline
post #9 of 12 Old 07-16-2014, 07:04 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
My Autometer FP gauge doesn't bounce, but I also have the Strictly Diesel relocation hose that lets you bleed out the air bubble.
"Rich is really good with knobs, his soft touch and attention to detail are like no other."-Portcity_gt
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #10 of 12 Old 07-16-2014, 07:13 AM
peixinho's Avatar
Quoted: 174 Post(s)
Maybe I should have specified that my "digital gauge" bounces. I have never seen an "analog gauge" bounce.
Not sure if that is a trend or just a coincidence
KC Turbos
peixinho is offline
