Nitrous on tuned truck? stock injectors/turbo - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-09-2014, 12:49 PM Thread Starter
Alright so I have a nitrous kit that is just sitting around that I never got to use and i figure why not put it on the truck? I know i will need to get a lighter tune that what i have on there now to compensate for it, along with new jets and a new solenoid but over all it could be more power for cheap.
Do you think I will see an decent improvement in power with stock turbo and stock injectors? Or is the truck pretty much maxed out and I will need to install injectors in order to take advantage of the N20? Not much comes up on this when i search it.
ARP studs, EGR Delete, Oil Cooler, Coolant filter, Blue Spring, Extreme X, PHP FICM Tuner, VDP Billet Wheel, MBRP Turbo back exhaust, Air intake, Tonneau Cover, Harley Lights, Pioneer speakers, In dash DVD Player
FordTech101 is offline
post #2 of 7 Old 07-09-2014, 03:34 PM
6 L chevy eater's Avatar
On ur race tune, if you have any fuel left (black smoke). There is more power to be made... Jus need the fuel to make the power...
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #3 of 7 Old 07-09-2014, 06:26 PM Thread Starter
I have black smoke when i punch it but that's about it. It clears right up, thats with using the Atlas 40... idk what Atlas tune would be best for nitrous though.
I would probably get a nitrous specific tune though. im sure it wouldnt pull to much HP from the tune that it would nullify the effects of the N20
Also --- i just found an article from deisel power mag where they put nitrous on a tuned 6.0 .... put down 371 hp with the tune and 441 with the nitrous... with my mods i was thinking i was closer to 420-430 BEFORE nitrous... if im looking at a max of around 450 with it I wouldnt even see the point... I would at least like to hit 500 with it, or am I dreaming.
post #4 of 7 Old 07-10-2014, 05:33 AM
if you dont have much fuel left there will be little benifts with nitrous, it will make less power if u run it to lean
2004 F250 ccsb
post #5 of 7 Old 07-10-2014, 06:14 AM
Chatham036's Avatar
Quoted: 146 Post(s)
The hp should still increase but you will reduce the amount of torque substantially
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #6 of 7 Old 07-10-2014, 09:46 AM Thread Starter
so if thats the case of Hercules tune would be better right? more fuel? then get a custom nitrous tune in order to help pull a little timing ?
post #7 of 7 Old 07-10-2014, 09:58 AM
u ever ran any nitrous Mr PHP?
2004 F250 ccsb
