Wanting up upgrade from stock turbo - Ford Powerstroke Diesel Forum
 24Likes
post #1 of 24 Old 07-09-2014, 07:39 AM Thread Starter
I am getting my studs done right now an I want to upgrade to a bigger turbo but I'm not sure what will be good with my set up.
I have a 8" Lift on 38's. Cai, 5" exhaust, egr, oil cooler SCT, CTS monitor. I have the blue spring kit they are gonna put on for me.
I tow a 24 car hauler full of dirt bikes an 30 ft travel trailer. It is my daily driver.
What yall think?
2014 Harley Davidson Big Blue Pearl Street Glide
Alpine fairing speakers
12" Ape Hangers
2006 Ford F350 King Ranch
BilletProof Oil Cooler Kit
APR Studs
Coolant Relocate Kit
Blue Spring Kit
New Motorcraft Injectors
8" lift kit 38x13.50x18
STC Edge CTS monitor
w/ Vivian tunes looney tune
5" Exhaust 8" Tip
APE Cold intake
50" Ridge Light Bar
Harley Davidson Black Headlights
[SIGPIC][/SIGPIC]
Dickey is offline
post #2 of 24 Old 07-09-2014, 07:47 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Well if I had the cash I'd give the guys at KC turbo a call.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 24 Old 07-09-2014, 07:47 AM
JGman141's Avatar
I'd look into re gearing before throwing a bigger turbo on, that would help out a lot more than a turbo IMO.
peixinho likes this.
2004 6.0 ccsb Warren 430/150 hybrids, Warren Comp Trans, Warren Dual Hpop, Billet S475 w/race cover, Marty's A1000 Fuel System, Colt stage 2 and all the other supporting stuff
JGman141 is offline
post #4 of 24 Old 07-09-2014, 07:59 AM Thread Starter
What size gears would you say to go with if I went that route?
12" Ape Hangers
APR Studs
Blue Spring Kit
5" Exhaust 8" Tip
APE Cold intake
50" Ridge Light Bar
[SIGPIC][/SIGPIC]
Dickey is offline
post #5 of 24 Old 07-09-2014, 08:12 AM
I'll be running 37's with 4.30 gears should have her back together pretty soon. I do not use the truck to tow so I'm not sure how much help I'll be
Yeeyee87 is offline
post #6 of 24 Old 07-09-2014, 08:15 AM
william_ace's Avatar
Quoted: 2 Post(s)
A re-gear with that size tire would be a great idea. 4.30s or 4.56. I'm on the fence on which ratio would work better with that large of a tire.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #7 of 24 Old 07-09-2014, 08:23 AM
bondajb's Avatar
4:30 minimum. . With a stg2
4:56 minimum. . With a stg3
that is my suggestion. .
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #8 of 24 Old 07-09-2014, 08:33 AM Thread Starter
How much was your gears? You having them done by shop or
You putting them in?
Changing the gears going to make that big of a difference?
12" Ape Hangers
APR Studs
Blue Spring Kit
5" Exhaust 8" Tip
APE Cold intake
50" Ridge Light Bar
[SIGPIC][/SIGPIC]
Dickey is offline
post #9 of 24 Old 07-09-2014, 08:49 AM
I went with Yukon gears front and rear I have a little over 800 in them that's oil and bearing kits as we'll, and I'm having a shop install them but you could do it yourself if you had time
Yeeyee87 is offline
post #10 of 24 Old 07-09-2014, 08:58 AM
bondajb's Avatar
I would have a shop do them if not familiar. .
Also.. put an 08 luvered diff cover on while at it
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
bondajb is offline
