New to this form sct towing questions - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-07-2014, 05:58 PM Thread Starter
jacobj011's Avatar
Ok first of all I'm new to this form and new to any form so I have a 2003 f350 6.0 powerstroke I have a 4 inch straight pipe turbo back with a powermax stage 1 turbo egr was deleted with 10 miles on it new hpop new injectors new icp new iPr new crank shift positioning sensor, it has a leveling kit on 37x20x13.50. . And I run a sct tuner.
My question is I pull about 23000 to 27000 pounds for work just curious when I know you shouldn't pull on performance or street with that much weight but dose the towing 65 will it pull better then street or performance would or dose towing physically change things to pull more efficiently this may be a dumb question sorry if I spelt anything wrong too
jacobj011 is offline
post #2 of 8 Old 07-07-2014, 06:12 PM Thread Starter
jacobj011's Avatar
Oh and I love my truck wouldn't trade it
2003 6.0 powerstroke lariat
Powermax stage 1 turbo
New Stock injectors
No head studs
New hpop and ipr
Sct tunes
37x20x13.50 under a leveling kit
And I love my truck ( mufasa)
post #3 of 8 Old 07-07-2014, 06:31 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 899 Post(s)
Feedback Score: 6 reviews
If you are pulling that much weight on a regular basis the I would suggest getting a good custom tow tune. Tow that much weight with a street or performance tune could lead to some damage. I have done it a few times myself, , but not on a regular basis.
Are you running just the canned tunes right now.
Oh and, you did spell a few things wrong , but we won't hold it against you too much.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is online now
post #4 of 8 Old 07-08-2014, 12:11 AM Thread Starter
jacobj011's Avatar
Yes I'm just using canned tunes, and I use it to tow that much almost every day the only thing I don't care for is how much turbo lag I have from the start and I'm kinda thinking the only way to get more power from the start is 4.10s I have 3.73s
New Stock injectors
No head studs
New hpop and ipr
Sct tunes
post #5 of 8 Old 07-08-2014, 09:30 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
If it were me pulling that much weight, stock tune only. 37' with 3.73 gearing is hurting your towing ability.
"Rich is really good with knobs, his soft touch and attention to detail are like no other."-Portcity_gt
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 8 Old 07-09-2014, 11:16 AM
jetjock15's Avatar
Quoted: 113 Post(s)
the towing tune will have less power then the other tunes. Some less fuel but mostly less timing advancment. If you towed with the performance setting you will feel more power but it will not last long until your heads pop or crack a piston. With daily towing I'd load the tow tune and leave it, or just run stock. Any 6.0 that tows that much daily has a lot of maintainence in its future, start saving...
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #7 of 8 Old 07-12-2014, 03:15 PM
jmeaby's Avatar
Quoted: 16 Post(s)
You need a custom tow tune for that powermax. That is part of your problem.. regearing you axles will help a lot as well.
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #8 of 8 Old 07-12-2014, 03:22 PM
fumoto valves.
Is it standard to leave the fumoto valves in the block for coolant draining?
Virgil B. is offline
