Confused on tuning... - Ford Powerstroke Diesel Forum
post #1 of 27 Old 01-20-2009, 01:00 PM Thread Starter
I am looking at an '04 crew 4x4 with 50-60k on the clock. I want good MPG. 20-22 hwy. Power seem ok stock. I would like to get exhaust turbo back and a free flowing air cleaner done. EGR elimination would be nice. Do I really need a tuner? I will be using this truck for camping towing a light trailer 2-4k and maybe putting a motorcycle in the bed while towing if I am getting away with the misus. I just want to get better milage than my gas truck does now.
molsen is offline
post #2 of 27 Old 01-20-2009, 01:09 PM
LHMissions's Avatar
You should already have better mileage in stock form then a gas truck.
I've got an '03 6.0, 174,600 on her, daily driver, 2.5" add-a-leafs and 33x12.5x16 Nitto's - I get 22 on the highway, 16 around town. My Superintendent has a F-150 super cab 4wd and gets like 11 around town and 15 on the highway. I've got a bigger and heavier truck and get better mileage then him!
if you get a tuner - it could help - IF you keep your foot out of it. More power = less down gearing = better mileage.
For the record - I dont have a tuner yet. Engine is stock except for the zoodad mod - which I cant say does anything really. I'm usually running with cab-height stake sides adding to the wind resistance too!
If you help the engine breath and exhaust with more flow - the benefit will be better mileage. How much is undecided as there is a broad range. But stock should get you around 20. Adding almost anything to it will help.
LHMissions is offline
post #3 of 27 Old 01-20-2009, 04:16 PM
03ccf350's Avatar
of course you will have enough power stock. you absolutely dont need a tuner if you dont want one. as you know, the truck was designed to pull by ford. we all here just want more. thats all. with an exhaust and intake, you will get an extra little more out of it while keeping stock egt's in check. will help mileage as well provided you keep your foot out of it. but if you decide to lay on it, it will still get better mileage than your gas truck.
clarence
03ccf350 is offline
post #4 of 27 Old 01-20-2009, 04:20 PM
im not up to date on the whole aftermarket seen but egr is to get more power thats why they put it in there if you dont know how it works the exhaust gasses cant combust so they absorb heat and lower egts and lower egts means more power. but like i said i dont know everything about all the after market deals if i am wrong some one please tell me i would like to know
power73strokin is offline
post #5 of 27 Old 01-20-2009, 04:20 PM
Goose350's Avatar
Its going to be hard to see 20+ mpg without a programmer
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #6 of 27 Old 01-20-2009, 05:33 PM Thread Starter
Goose is there such a setup that would be for economy w/o really adding all that much power? I just curious. I know by making the engine run well, it will in turn run more efficently(sp?). I just thought simple mods would be enough.
molsen is offline
post #7 of 27 Old 01-20-2009, 05:36 PM
Goose350's Avatar
Well, the more hp you add, the better milage your going to get as long as you drive it to get better mpg. I dont even have a economy tune on my sct. If your not dogging it all the time, the higher HP tune will get better mpg
EDIT: yes, there are tuners out there that are just for fuel economy but it wouldnt be worth buying
The Mullet Mod
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #8 of 27 Old 01-20-2009, 11:52 PM
fordfan30's Avatar
I knocked out 21mpg this past summer running extreme street. I would get 16-17 in stock form at best.
06 F250 4x4 ecsb, lowered 2", 6 Autometer Phantom 2 guages, Accufab Elbow, Zoodad, Airaid , Magnaflow 4"dp, 5" pipe 7" short stack, Studs, Egr delete, sneaky pipe, regulated fuel return, 6.4 banjo bolts, Moderate FICM from Innovative, High idle and foglight mods, Bilsteins, Sulastic shackles, DIY Harley headlights and traction bars. 8.76 in the 1/8th
fordfan30 is offline
post #9 of 27 Old 01-21-2009, 04:04 AM
Davey~do's Avatar
I havent done the exhaust yet, but it is on my list of things to do. But for certain, adding a tuner should help your milage, IF you drive the truck to save fuel. I bought a X3 from Raul a couple months ago and have seen my milage increase from 16.5 stock, to 18.5 on street to 20 on extreme street. This is mixed city/highway on my commute from work.
David
2016 CCSB SRW FX4
Davey~do is offline
post #10 of 27 Old 01-21-2009, 05:00 AM
Raging Lunatic
choctaw's Avatar
Someone correct me if I am wrong..........EGR is NOT there for more power it is there to provide cleaner exhaust, to meet EPA standards.
Halito...Sa hohchifo ut Mike
On EARTH as it is in TEXAS
ΜΟΛΩΝ ΛΑΒΕ
"Fast Service Guaranteed...No Matter How Long It Takes"
choctaw is offline
