Manual or Automatic hubs - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-06-2014, 10:04 AM Thread Starter
silverstroker04's Avatar
Ok. Just broke my hubs the other day pulling out a Dodge out a muddy field (worth it lol). But now I'm in need of some advice. Do I go with manual hubs or stick with my factory automatic hubs. I had the hubs covered before with caps for a cleaner look but since horsepower has grown since then I'm wondering if I should enable towards durability than style. If there are aftermarket auto hubs out there as tough as manual Warn hubs for example point me in their direction. Thanks.
silverstroker04 is offline
post #2 of 9 Old 07-06-2014, 10:12 AM
ZMANN's Avatar
Quoted: 1462 Post(s)
it would cost me thousands to go with a manual upgraded hub since you have to delete the unit bearing to do so on ours search spyntec and dynatrac
otherwise the OEM Warn is it, they make a manual version but it is the same hub minus some parts
what year is yours ?
We Miss you Ronnie
ZMANN is offline
post #3 of 9 Old 07-06-2014, 10:24 AM
I'm old and lazy, replaced my stuck autos with new oem I found cheap on ebay, too many years climbing in and out to lock and unlock. The warns on my CJ5 stay locked all the time.
03 F-250 6.0 Black/Gold Lariat CC SB FX4
jsm180 is offline
post #4 of 9 Old 07-06-2014, 10:30 AM Thread Starter
It's an 04. From what I can tell if I just plugged off the vacuum and put manual in shouldn't be an issue. Unless I'm missing something.
post #5 of 9 Old 07-06-2014, 11:48 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The factory hubs are auto and manual, no need to go just manual.
This is one thing I like about the Fords. The Dodge only has auto hubs, which sucks if you get a vacuum leak in the system, no way to override it if you get stuck.
ZMANN is referring to the free spin manual hubs. It's like the old school style that when the hubs are unlocked, it won't draw parasitic MPG loss from the axles spinning.
"Rich is really good with knobs, his soft touch and attention to detail are like no other."-Portcity_gt
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 9 Old 07-06-2014, 12:29 PM Thread Starter
Automatic it is. Aftermarket or factory OEM?
post #7 of 9 Old 07-06-2014, 12:32 PM
ZMANN's Avatar
being an 04 you may have an option
I do not but your right at the changeover year
We Miss you Ronnie
ZMANN is offline
post #8 of 9 Old 07-06-2014, 04:21 PM
strokin6L's Avatar
Quoted: 3 Post(s)
When my factory auto hubs seized up....I switched to Warn manual hubs. I love them and they were cheap....$250 for both. Pretty easy switch....just pull factory hubs out and install the Warns. Had them done in less than an hour.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #9 of 9 Old 08-11-2014, 12:22 PM
Send a message via AIM to F350CCFX4
Have a part number?
2004 SRW CC
Mods:
Airraid, MBRP 4", Banks Intercooler, Kermit Tunes, Banjo Bolts,ScanGaugeII,Autometer Z series, Boost, EGT, Fuel Pressure, Trans Temp., LOP, Volt,ARP Studs
F350CCFX4 is offline
