Custom fuelab system - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 25 Old 07-03-2014, 10:28 PM Thread Starter
Hey guys just ordered a fuelab pump, I got a few questions.
I have a regulated return and 5/8 pickup tube. I want to run 5/8 line to pump and 1/2 to the motor with a 3/8 return all the way to the tank. I would like to keep my fuel bowl if I can hold pressure with it on this set up feeding 190/75s
Does anyone know what fitting I would need? I don't have a clue what size the fitting is where I would tie into the fuel bowl. I also don't know what size the fittings the return from the bowl takes, the pump or the filler heads?
Any help is much appreciated, I still need to order the filter heads, filters, hose, fitting, and electrical components. Let me know how you built your system if your using a stand alone pump! Thanks!
bwstone92 is offline
post #2 of 25 Old 07-03-2014, 11:11 PM
Real Men of Genius
Super Diesel's Avatar
Quoted: 10 Post(s)
Feedback Score: 9 reviews
I can't remember all of the specifics, but I think the fitting to the fuel bowl is a banjo bolt. I used a banjo bolt to -8AN fitting for that... but I can't remember how big my lines were. I used Earls Performance fittings on just about everything. I'll dig up my specs and send you what I got.
I'm running a sump, to an AD150, to a fuelab 41402, to the fuel bowl, and finally out thru a Driven Diesel RR. My fuel system was planned out by Nate (Windrunner). I like the way it came out. It's definitely enough to feed my 190s.
Chris | 2005 F-250 RCSB | "Ranger - Turbo Diesel V8"
CED Compounds - Conventionals - Supporting Mods
Super Diesel is offline
post #3 of 25 Old 07-04-2014, 06:41 AM
dashy's Avatar
Quoted: 3 Post(s)
M16x1.5 is the return off the bowl.
Check out this thread might give you some more info:
Custom regulated return help
06 rclb 4x4 xlt sct with tsd and gearhead tunes, ARPs, egr delete.
dashy is offline
post #4 of 25 Old 07-04-2014, 08:15 AM
snafu!'s Avatar
Mine goes from a sump to 10an ---> water separator --> Fuelab --> fuel filter --> 8an to motor --> Y block --> 6an --> 90 fittings on front of heads --> 90 fittings back of heads --> to fuel pressure regulator --> back to tank.
I have the pump and filters mounted on the inside of the frame on a bracket I built.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #5 of 25 Old 07-04-2014, 09:24 AM
dieseldan73's Avatar
Mines going to be just like yours! just got to fab up a bracket and get the rest of my fittings.
ODAWG714, Diesel996 and snafu! like this.
2005 Ford f350 CCSB King Ranch
MTW MadMax Turbo
Warren 155/30 injectors
EGR Delete
BPD Oil Cooler, FICM, Oil Bypass, Water pump
Flo-Pro 5" Exhaust, Cat Free, Muffler Free
All updated FORD Parts
ARP Studs With Factory Gaskets
PI Stallion Converter
TSD SPD. Thanks Chris,
Edge CTS monitoring
35x12.5x20 Dick Cepek FC-2 on Chrome Rockstars
4" Zone lift with Bilstien 5100's
dieseldan73 is offline
post #6 of 25 Old 07-06-2014, 04:37 PM Thread Starter
Haha I would hope so, I heard a 41401 is enough to feed 190s alone
post #7 of 25 Old 07-06-2014, 05:04 PM
snafu!'s Avatar
41401 is big enough for 400cc injectors. Lol
ODAWG714 likes this.
Cameron
Warren 285/100
ODAWG ported intake
Built Trans
Water/Meth
snafu! is offline
post #8 of 25 Old 07-06-2014, 06:30 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
Nice setup boys! Cameron I like that shut off valve
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #9 of 25 Old 07-06-2014, 06:44 PM
Actually, I was looking for a shut off valve like that. What size is it and do you have a part number?
MTW MadMax Turbo
EGR Delete
Edge CTS monitoring
post #10 of 25 Old 07-06-2014, 11:34 PM
snafu!'s Avatar
I had to get pretty creative to fit everything between the fuel tank and transfer case. There's not much room on a short bed. The valve is a JFW 3/4" stainless I got from a local hydraulic shop. I used a 3/4 NPT to 10an JIC fitting to connect it to the filter base. They have the same thread as a ORB fitting so I just installed a O ring on the JIC fitting. IDK if you can see in the pic but the 10an hose from the sump runs through one of the holes in front of the fuel tank. In the front I had to use a 10 AN ORB to 8AN 45 to clear the transfer case.
Overall I'm happy with it, the cross member protects the filter. I would like to make a bracket to protect the water separator.
Cameron
Warren 285/100
ODAWG ported intake
Built Trans
Water/Meth
snafu! is offline
