mod. turbo - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-02-2014, 06:45 AM Thread Starter
mod. turbo
ok first of I know some have mod. there own turbo aka stage one. I have a billet single plane powermax wheel and am wanting to install in my stock 04 turbo. I have a friend who can do the machine work but has never done one. my question is do you just bore out housing to accommodate or is the radius different on the stock vs powermax?? he said everything would be easy to do he was just conserned on the radius of the wheel being different? any help would be appriciated thanks
kgbusa68 is offline
post #2 of 13 Old 07-02-2014, 06:59 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
The "curve" (as we'll call it) is actually compound radius that has three parts to it. It's not just one simple curve with a given radius. It's gonna be pretty tough IMO to get the right curve by just having a wheel. Ideally you'd need a Powermax cover and then translate that curve to the OE stock cover.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 13 Old 07-02-2014, 07:20 AM Thread Starter
I was thinking the same thing but having a hard time finding just a cover for sale....I have been looking at your diy kits you sell and funds arnt there just yet but I know covers are fairly inexpensive too need to just find one.....Also I have seen a few members here that have machined there turbo housing to accommodate. I have pm them and was hoping they would shed some light on what they have done too...
kgbusa68 is offline
post #4 of 13 Old 07-02-2014, 07:35 AM
peixinho's Avatar
Quoted: 215 Post(s)
Excuse my blunt comments... LOL
anyone can half-A$$ a cover and physically fit the wheel inside of the compressor cover. But if the person cutting the cover is asking if the radius is different... then he should not be cutting your cover. The tolerances are very tight and even the most skilled machinist can mess it up.
If the cover is cut to tight then the wheel will rub and possibly blow up your turbo. If the tolerance is too loose (which is what most people do to avoid rubbing) then you will end up with a poor performing turbo.
I love the DIY stuff and always promote it... but be careful that you don't end up with a blown up turbo or a poor performing turbo
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #5 of 13 Old 07-02-2014, 07:50 AM Thread Starter
so probly find a pmax housing would be better huh
kgbusa68 is offline
post #6 of 13 Old 07-02-2014, 07:52 AM
jmeaby's Avatar
Quoted: 16 Post(s)
Just my thoughts on what Charlie said.... Be prepared to screw up haha. Like said before it's hard
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #7 of 13 Old 07-02-2014, 07:54 AM
jmeaby's Avatar
Quoted: 16 Post(s)
Other note which stock turbine do you have? Ten blade or 13? Not sure how they do with the 13 blade butnate and Charlie can chime in. I would listen to those guys they know their stuff.
04 f250 cc sb.
jmeaby is offline
post #8 of 13 Old 07-02-2014, 07:54 AM Thread Starter
if it were easy everyone would be doing it lol.....but it can be done
kgbusa68 is offline
post #9 of 13 Old 07-02-2014, 08:36 AM
HP MACHINE's Avatar
Quoted: 152 Post(s)
Send the cover and wheel to WPE,KC or Barder and get them to machine it .Do the back plate yourself and go to town . The shipping wouldn't be too bad compared to sending the
whole assembly .
HP MACHINE is offline
post #10 of 13 Old 07-02-2014, 08:55 AM Thread Starter
ok will do
kgbusa68 is offline
