Air intake filter problems - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Babyboy70363
post #1 of 7 Old 06-30-2014, 10:57 AM Thread Starter
BigRedOne's Avatar
Quoted: 5 Post(s)
What kind of air filters is everyone running? I am running a K&N cone but I recently did work to the truck including tunes and when I opened the hood today, my cone filter was all but turned inside out. WOT I am seeing between 23-28 PSI. The filter is obviously restricting the flow enough to be caving in.. and this filter was new and clean. I replaced it with my Green filter and one WOT run it destroyed it. Collapsing it completely. What filters stand up to the high flow demand of high boost?
2005 F350 XL 6.0
ARP studs
EGR delete
5" turbo back straight pipe
AFE intake
BPD 58v FICM
03 turbo
Sinister Y pipes
SCT tuner
Edge insight cts
All upgraded OEM parts
BigRedOne is offline
post #2 of 7 Old 06-30-2014, 11:21 AM
Quoted: 8 Post(s)
S&B, most here will tell you the K&N is junk on our trucks and will cause issues with your turbo!
ZMANN likes this.
2005 F250 FX4 6.0 PowerStroke, Dashboss, Swamps 58V FICM, PHP Atlas 40 tune, Tony Wildman Extreme Tune, IPR Coolant filter, ELC Coolant, EGR....nevermind, updated stc, more to come!
Babyboy70363 is offline
post #3 of 7 Old 06-30-2014, 12:10 PM
SargentoPistola's Avatar
OEM is a good filter. As stated above S&B is also a good option.
-Kyle-
2004 6.0 Eddie Bauer Excursion. The Man Van.
SCT w/ MPD
Edge CTS w/ EGT Probe
Banks exhaust
EGR Delete
Coolant Filter
Riffraff Boots
Stuff
1999 F-150 XLT 4.6 4x2. The Backup.
SargentoPistola is offline
post #4 of 7 Old 06-30-2014, 12:15 PM
OEM good up to 500hp
RedBigBertha is offline
post #5 of 7 Old 06-30-2014, 01:11 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 11 Post(s)
Feedback Score: 3 reviews
S&B makes direct replacements for the K&N kits.
http://www.sbfilters.com/index.php/p...html?cat=15271
"Rich is really good with knobs, his soft touch and attention to detail are like no other."-Portcity_gt
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #6 of 7 Old 06-30-2014, 06:38 PM
6 L chevy eater's Avatar
AFE makes good filters also, on there website you can Actually "build your own filter" pretty neat optoin
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
post #7 of 7 Old 06-30-2014, 07:26 PM
Regardless of media type an open element under the hood is about the worse type of filter for power as the IAT1 temps will be about 40*F higher. A good filter element whether aftermarket or stock with a snorkel that uses the factory location or there about is great. I have found that I like the AIRAID drop in which I use a non factory element which uses a factory setup so the MAF readings are correct. Normally though I just use a stock element.
2003 F350 6.0L KR CCLB DRW 4x4 auto - bone stock
Edge insight, EAS EGT, turbo timer
Strategys, DAX0-1;TEC0-7
Ford Pilot injection
2005 F250 6.0L XLT CCLB 4x4 auto
Strategys, UPV1;URV0;CYH0-7
PowerMax-KTS 11 blade SP Billet
ARP studs, BPD EGR cooler, 04 uppipe
Banks intercooler system, Airaid Dropin
4" turbo back Magnaflow exhaust w/4" DP
SCT 3015
ID custom tunes
ID Pilot-Injection
ID FICM tune
U235a4 is offline
