New 6.0 with goodies - Ford Powerstroke Diesel Forum
post #1 of 1 Old 06-29-2014, 09:47 PM Thread Starter
Ok buying my first 6.0 which is my bosses truck that he just built which we did all the work so I'm not buying a modded truck that I don't know or don't know who did the work I'm just a 7.3 guy. The truck I'm buying is a early 03 4x4 cclb new everything top end of motor mods are studs with oem gaskets,egr delete, rr,our ported intake,warren 175/75s,62 non vgt with new up pipes ,bank inter cooler with pipes, innovative tunes which will be getting changed for probably tsd tunes. The problem I'm having which I think is tuning is when from 5-10 mph roll and hammer on it yesterday I shifted to 2nd then nothing and acted like it was neutral manually put in neutral and then back to drive and it drove fine, normal driving conditions it shift HARD into gear but under kinda accel it shift pretty good and slams you in your seat, which is why I'm thinking tuning. I think some of the problem lies in tires as they 285s worn out but will be going to 35s and adding a air dog 165 quick connect kit, we have never had the truck dynoed and I'm hoping the truck makes about 500. Any responses on the trans issue would help and any ideas on number would be great full also. Thanks
Brandon4685 is offline
