Anyone tow occasionally with Stage 3 KC Turbo and Larger Injectors - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 20 Old 06-28-2014, 09:13 AM Thread Starter
I don't tow anything at all and I kept this in mind when making the decision on the mods I wanted to do from the very beginning when my truck was bone stock less than 1 year ago. The general consensus was that installing the stage 3 and larger injectors pretty much retires you're truck of any dedicated towing capabilities. No big deal for me. Only thing I haul is *** and the occasional sport bike to do track days.
My new Stg 3 turbo, 190/75 injectors, and WPE race ported manifold are still sitting in my garage, and as soon as I can spare the truck being down for about a week, I plan on putting these last 3 big items on.
With that said, just wondering if I HAD to tow something, would I have any issues? Just something that came to mind last week when I had to tow about 8k lbs which was a spur of the moment thing and the first time I towed anything with this truck since I bought it.. I was thinking once all my mods are installed, that maybe I should get a dedicated towing tune to account for the larger injectors and turbo JUST in case a need like this arrises in the future.
Anyone tow occasionally with this turbo and larger injectors?
2007 Ford F250 CCSB - Daily Driver
KC 68mm Turbo, WPE Intake Manifold, 190/75 Inj, Reg Return Fuel Sys, FASS 200gph, 58v FICM, 4" Exhaust, Studs, EGR Delete
670RWHP / 1153RWTQ-Fuel Only
2000 Ford Lightning SVT - Weekend Toy
Built Motor, Whipple 3.4L SC, Heads, Cams, Fuel System, Exhaust, Suspension, Full interior with AC
10.9 @ 124mph on 18" Drag Radials and 93 Pump Gas
ZaC851 is offline
post #2 of 20 Old 06-28-2014, 09:28 AM
william_ace's Avatar
Quoted: 2 Post(s)
I would think with a good tow tune that you should be able to tow okay on ocasion. I'm going with 205/100s, race manifold and a barder 68mm and wont hesitate to tow. I'll just have to keep a good eye on what the EGT's are doing. I THINK you'll be okay.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #3 of 20 Old 06-28-2014, 12:21 PM
strokin6L's Avatar
Quoted: 3 Post(s)
I'm running a KC 68 with 190/75's....but haven't towed anything yet
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #4 of 20 Old 06-28-2014, 12:31 PM
peixinho's Avatar
Quoted: 199 Post(s)
Hopefully some more guys with personal experience can chime in...
I personally have towed with 175/75 with no problems... as long as I was on a tow tune then everything was fine. DONT EVER TOW ON A RACE TUNE. It is not just about egts... it also has to do with timing and cylinder pressures.
I know Jared (gearhead 2012) here on the forum has towed 8000 lbs lifted on 37" tires and stock gearing with no problems. He is running 175/30 and KC68
I have another guy named Nick who owns CN Diesel who has towed upwards of 15000 lbs and said it did great.
Andy Warren from Warren diesel was towing over max weight (I think around 20,000 lbs) and said it did great
Your cruising egts will be a little higher than normal (but still in the safe zone). But when pushing it hard up a hill the turbo should do aweseom.
Get a good tow tune written that prevents going into OD too early and not to lock up the tq converter too early and make sure they pull plenty of fuel. You should be fine. Let me know if you have any specific questions
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #5 of 20 Old 06-30-2014, 07:19 AM
Chatham036's Avatar
Quoted: 136 Post(s)
I just installed 225/75 injectors in my truck and towed approx 9000lbs ( tractor / trailer ). My truck is currently tuned for 190/30 injectors; not the 225cc's that are installed. Cruising up a pretty steep incline ( I speculate to be 6 % ) I was able to maintain 1100 degrees even with the mass fuel desired tables being skewed outside of 'allowable parameters'.
The turbo was able to keep the engine very cool. That is the thing I like the most about the KC68 is that it flows A LOT of air when needed.
Once I tune my truck where it needs to be for the recent modifications, I wouldn't hesitate to hook up to 15,000 lbs with this charger on a tow tune. It works very well.
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Chatham036 is offline
post #6 of 20 Old 06-30-2014, 07:56 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
Now that it has warmed up, up here in Canada I will say that the temps I see are on the higher side than I would like. At 65 mph towing I am seeing about 1050* as a typical temp on level ground, so I am about 100-150* warmer than I used to be on the same tunes with my stage 1. At 55-60 mph the temps are better and when in 5th at higher RPM (50-55 mph) the temps are about 850*. This is pulling my wakeboat (6,000 lbs) which does have a larger wind catch than my heavier horse-trailer. Climbing hills I have seen 1,200-1300* even at lower speeds in OD.
One thing I have noticed for DD trailerless, as initially described by Charlie prior to putting on the KC-68, is the typical temps are now 50-100* warmer than when I had my stage 1 turbo on the truck. In the winter months, there was not any noticeable increase. As well, lately my boost is about 1-2 psi lower at cruise. I will say the fuel economy is better with slightly lower boost at cruise, but the temps will be higher. I have no leaks and I have cursorily checked the turbo (comp section and finger bearing test). I still need to pull the turbo to check the turbine. I would agree that tuning, specifically for the turbo, will keeps the temps in control. I have not tried my new tow tune yet as I was establishing a base-line from what I had done last year.
FWIW, my trans temps haven't got above 160*. I have also been suffering what I believe to be T/C and/or transmission issues, but none of the typical symptoms are showing, or continuous; nor do I have any codes yet.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 20 Old 07-01-2014, 08:46 AM
bootcamp's Avatar
Quoted: 3 Post(s)
What is consider a safe EGT and for how long can you run a high EGT?
USMC
05 F250 6" LIFT, Custom Fuel System, RR KIT, Fuel, TRANS, OIL, PYROMETER GAUGES, Fluid Damper, TSD & IDP Tunes, HellmaNs Sump, 4.10 Gears, ARP +625,Factory Gaskets,Apex ported manifold, MBRP EXHAUST , Atlas 40, Warren 175/75 injectors, 68mm Pmax w/ Batmowheel, BPD rad, BPD water pump, Sinister Y Pipe,Alradco Intercooler, O-Ring Heads and the list goes on.
bootcamp is offline
post #8 of 20 Old 07-01-2014, 09:18 AM
Chatham036's Avatar
Quoted: 136 Post(s)
You shouldnt sustain over 1200 degrees EGT for any extended period of time. ( less than thirty seconds )
The Following User Says Thank You to Chatham036 For This Useful Post:
bootcamp (07-02-2014)
post #9 of 20 Old 07-01-2014, 10:07 AM
strokin6L's Avatar
Quoted: 3 Post(s)
I can nearly hit 1100* accelerating moderately from 0-50mph only using 15-20% throttle on flat ground.
post #10 of 20 Old 07-01-2014, 02:26 PM
6 L chevy eater's Avatar
egts are like age, there just a number. LOL
scparrish, ODAWG714 and snafu! like this.
2004 F250 ccsb
Skint Back Motorsports
Warren-HYBRIDS-- S400
FULL Billet Twisted Diesel Built Tranny
10.90@124 on fuel dammit
6 L chevy eater is offline
