SINISTER HEADERS AND Y PIPE - Ford Powerstroke Diesel Forum
 14Likes
post #1 of 26 Old 06-27-2014, 05:41 PM Thread Starter
F350Powerstroker's Avatar
Question SINISTER HEADERS AND Y PIPE
Anybody running the sinister headers and/or Y pipe? Been looking into doing them and would like to hear from anyone that has them! Appreciate it!
~1973 F250 Highboy
~2003 F350 Super Duty XLT FX4 6.0 Powerstroke
4.56 Yukon Gears,Detroit Locker,37x13.5x17 Interco Super Swamper M16,8in Custom Lift,Bilstein 5125 Custom Valved Shocks (Triple Front/Dual Rear),Fabtech Dual Rear Shock Kit/Traction Bars,ARP Head Studs, Sinister Headers/Y Pipe/Regulated Return,175 cc Injectors,Edge Juice Platinum with Attitude,SCT Tunes,Snow Performance Stage 3 Water Methanol Injection,FASS 150/180,Banks Techni-cooler System,Fluidampr,4in Straight Pipes.
F350Powerstroker is offline
post #2 of 26 Old 06-28-2014, 08:42 PM Thread Starter
Nobody is running them!? Anybody...
~1973 F250 Highboy
post #3 of 26 Old 06-29-2014, 02:15 AM
strokin6L's Avatar
Quoted: 4 Post(s)
There's a few running their y-pipe....but haven't heard of anyone running their headers. Don't think you're gonna get any good feedback on their headers. Its because headers don't work well compared to log style manifolds on a diesel. They'll warp and crack due to the high egts that a diesel sees compared to a gas vwhicle.. Guys have experienced issues when trying headers.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #4 of 26 Old 06-29-2014, 04:35 AM
Real Men of Genius
Super Diesel's Avatar
Quoted: 10 Post(s)
Feedback Score: 9 reviews
I've heard nothing but good things about their y-pipes.
Chris | 2005 F-250 RCSB | "Ranger - Turbo Diesel V8"
CED Compounds - Conventionals - Supporting Mods
Super Diesel is offline
post #5 of 26 Old 06-29-2014, 08:46 AM
Curious, do their Y-pipes already come with a bend that you need in them to fit most regulated return systems?
Sent from AutoGuide.com App
DieselEnthusiast is offline
post #6 of 26 Old 06-29-2014, 09:05 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Nope... But most RR kits use banjo fittings instead of 90* fittings so it probably doesn't matter.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #7 of 26 Old 06-29-2014, 10:22 AM
Sweet, thanks.
post #8 of 26 Old 06-29-2014, 03:45 PM
madpowerstroke's Avatar
I run their y-pipes and from my experience with others they are the best ones out there. Not having bellows, but instead using slip fit is nice, and the way the pipes come together at the collector is very nice. I have 90 degree fitts for the regulated return and don't have any issues with the y-pipe clearance.
As far as the headers go, I have tried some in the past and wasn't too impressed, I how ever do plan on trying out a set with the y-pipe. Problems I had with one set of headers was getting them to seal tight to the heads, but I have a fix for that, so I will give them another try. One of the aftermarket manifolds I would like to try would be the ones made by BD, since they are log type. I like the factory log type for street since they spool turbos better, the ones I want to try are going to be for strip so they are going to be tubed type.
2004 F250 Ext.cab fabtech 5.5" lift,and traction bars 35" on 18".2005-2007 grill and LED headlights,58v FICM, Warren dual HPOP system, fuel reg. return system, areo 1000a fuel pump, dual fuel filters, ARP studded heads, CCV reroute, EGR delete, 225/75 Warren injectors, water/meth injection (cooling mist),SCT tuner with customs, banks intercooler. MTW stage 4 turbo, built trans by Andy Warren, 4:10 Detroit lockers.
madpowerstroke is offline
The Following User Says Thank You to madpowerstroke For This Useful Post:
F350Powerstroker (06-29-2014)
post #9 of 26 Old 06-29-2014, 04:55 PM
I'll be using the BD manifolds in my build as well. I like how they are pre drilled for EGT probes.
post #10 of 26 Old 06-29-2014, 04:59 PM
strokin6L's Avatar
Quoted: 4 Post(s)
Been running the BD manifolds for 500 miles so far. No complaints yet!
HeavyAssault and Merc82 like this.
