p0264 code - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-26-2014, 06:51 PM Thread Starter
strokin6L's Avatar
Quoted: 3 Post(s)
p0264 code
Well decided to check the IAT sensor today to see if it looked ok and wasn't all carboned up. Pulled it out and looked clean as a whistle. Reinstalled and started the truck up. All of a sudden after start up truck idled really rough and shook pretty bad. Took it for a little drive and still idled rough after I got back. I shut it off and checked ICP connector...that checked out ok. Wiggled the harness where I disconnected the IAT sensor...only because that was the only part of the harness I touched. Started truck back up and still idled rough. Then all of a sudden I got a CEL...p0264 for cylinder #2 injector circuit low. It got late and dark so I didn't look into it any further. I'm thinkin either the injector harness connector at the FICM, injector harness connector at #2 injector or a pinched wire inside the harness. Either way I'm leaning towards something with the injector harness. I have a brand new sitting here that I've had for a spare. What do you guys think?
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #2 of 3 Old 06-26-2014, 10:53 PM
snafu!'s Avatar
I'm dealing with almost the same problem right now except mines cylinder 6. Ohmed the injector and it was out of spec so ordered a new one from Warren and that didn't fix the problem. I have a new injector harness on the way and going to get a known good ficm from Dale. He also said it is sometimes the connector on the harness, if the gold plating is worn or connector is burnt it will cause a problem.
Cameron
2006 F250 Lariat CCSB
Comp Turbo 64/88 compounds
Warren 285/100
ODAWG ported intake
R&R rods, mahle pistons, stage 2 colt cam
Built Trans
Water/Meth
snafu! is offline
post #3 of 3 Old 06-27-2014, 06:14 AM Thread Starter
strokin6L's Avatar
Quoted: 3 Post(s)
Fixed it. It was the injector plug on #2...It was loose. Took the clip off, reconnected and reinstalled the clip and purred like a kitten.
