BULLETPROOF 6.0L - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 18 Old 06-26-2014, 01:52 PM Thread Starter
OutLaw11's Avatar
BULLETPROOF 6.0L
I once had a 2006 6.0, then was stolen from me . I was running Cale's, Eric's and Tony's tunes. This was back in 2008-2009, dont know if these guys are still on here (Im sure they are) I now own a 6.7 and LOVE IT.
BUT.... I am bored and want to build me a single cab with "more" performance. Found a 2005 6.0L with 105k miles for 6k.
Before I "tune" it, I want to "bulletproof" it. Just looking for some advice as to what EXACTLY I need to push this motor hard and not have problems.
THANKS GUYS! and Gals!
OutLaw11 is offline
post #2 of 18 Old 06-26-2014, 03:06 PM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
IMO, considering that you bought this truck as a toy, I'd recommend starting with a brand new long block that has OEM HGs and some sort of stud (preferably either ARPs or Xtreme Studs) and not factory head bolts. This along with a built transmission, EGR delete, and custom tunes will give you a VERY solid foundation from which to build power from (of course after you've broken in the new long block properly).
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #3 of 18 Old 06-26-2014, 04:21 PM
jmeaby's Avatar
Quoted: 16 Post(s)
What is your price range to have work done on it? Head studs is a must. How far do you wanna take the build do you have a hp number in mind or just a really fun grocery getter
04 f250 cc sb.
Egr block off, 4 inch turbo back ss magnaflow exhaust, billet turbo wheel, 05 Harley headlights, S&B intake, XDP coolant filter, tuned with Sct by PHP, BDS Dual rear add a leaf, Firestone ride rite airbags, 2 12 inch kicker subs, infinity rear speakers, mb quart frontdoor speakers, mb quart amp, autopumpkin Android headunit, torque pro.
jmeaby is offline
post #4 of 18 Old 06-27-2014, 05:26 AM
scparrish's Avatar
Quoted: 109 Post(s)
Feedback Score: 3 reviews
Yeah you will have to start by setting some goals. Nate has provided a great starting point for sure.
White Early 2004 F250 Harley
Adrenaline hpop, Aeromotive, ARP, BPD, BTS, Carli, Fox, Fuelab, GH/TSD/Wildman, Holders 225/75, KC Stage 2 Turbo, PHP FICM Tuning, PMF, S&B, Mishimoto rad/ic, 08 axle swap 3.73 gearing
scparrish is offline
post #5 of 18 Old 06-27-2014, 06:06 AM Thread Starter
OutLaw11's Avatar
I have priced a "bulletproof kit" for around $1400 and $1500 for installations including fluids. so im around 3k already. Think im going to head that direction, then ill spend a grand or 2 more on paint and wheels.
I dont want a complete race truck, just a sweet grocery getta!
OutLaw11 is offline
post #6 of 18 Old 06-27-2014, 06:31 AM
peixinho's Avatar
Quoted: 231 Post(s)
Be careful with some of those "bullet proof" kits.
Some of them use sub par parts like black onyx gaskets, dorman oil coolers, euraisa studs, etc... make sure that you get the good stuff and not the cheap knock off parts that are known to have problems.
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #7 of 18 Old 06-27-2014, 06:33 AM Thread Starter
OutLaw11's Avatar
EXACTLY! I know im going with FORD OEM gaskets.
Can you guys give me a list of the "GOOD" brands?
i would really appreciate it
OutLaw11 is offline
post #8 of 18 Old 06-27-2014, 06:37 AM
jmeaby's Avatar
Quoted: 16 Post(s)
If that's the case I would heads done right buy your parts separately not in a kit so you know you are getting good parts not cheap craps that will fail. While you have it apart I would upgrade injectors to 175 or 155. Then talk to Charlie or nate about some turbo options and throw one of there ported intakes in. After that I would be surprised if you said you wanted much more in a regular cab truck . Also don't forget a monitor to keep a eye on everything
04 f250 cc sb.
jmeaby is offline
post #9 of 18 Old 06-27-2014, 06:39 AM Thread Starter
OutLaw11's Avatar
That sounds more ideal, buying parts individually. Just wish i knew brands that are working and brands that go to craps!
OutLaw11 is offline
post #10 of 18 Old 06-27-2014, 07:17 AM
Brew_WY's Avatar
Garage
You can't go wrong with ARP fasteners. OEM head gaskets, OEM oil cooler and gaskets. I would go with a River City Diesel EGR delete or a deleted "Race" manifold from WPE. I would also add a dieselsite or sinister coolant filter. That would be my start on it.
Here is a good thread with lots of part numbers.
Head Stud Thread
2003 6.0L PSD Excursion Limited 4x4
Edge Insight CTS w/Dash Pod, EGT, TT, Back Up Camera
AMSOIL with REV-X
AMSOIL Bypass Oil Kit
GDS Fuel Spring
Diesel Site Coolant and Transmission Filters
Brew_WY is offline
