Initial impressions of my build - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-26-2014, 10:08 AM Thread Starter
Simply put, I love it. Studded, deleted, Barder stage 2, SCT with a whole bunch of custom street, track, and tow tunes, PHP Ficm tunes, AFE stage 2 CAI, AFE intercooler tube, Edge Insight CTS, blue strings, 6.4 banjo bolts, and likely some other things I'm forgetting.
So far, I have put roughly 500 miles on the truck since its been done. For the first few days I ran it with a Loony Wild tune and the Atlas 80 FICM tune. Its got some lag off the line but it hauls when I'm in the boost.
On monday, I towed with it for the first time. Weight of the trailer was roughly 5k pounds. I used the Gearhead 8k tow tune but kept the Atlas 80 on. EGTs ran up to about 900 on normal acceleration and peaked at 1200 during the largest incline I encountered. At speed, EGTs were around 750.
Today, I had a 12k pound trailer to haul around. For this I used the Atlas 40 with the Gearhead's Max Tow tune. Again, EGTs peaked at 1200 and were in the high 800s to mid 900s during acceleration and in the 700s while cruising.
After dropping off the trailer, I put the Loony Wild back in but decided to try the Hercules FICM tune. It still has quite a bit of lag if I get on it right off the line but the throttle response during regular driving seems much improved. EGTs under heavier acceleration were in the 900s-low 1000s getting to speed and dropped to the 500-mid 600 range while cruising. Under normal acceleration, EGTs were in the 700-800 range.
As far as MPG, my first tank with no towing yielded 12.5mpg. Right now, being slightly more accustomed to the truck and even despite still getting on it more than I probably should and all the towing, based on my fuel gauge, I'd estimate I'm going to be around 14.5-15 mpg. Before the build, when stock, I typically averaged 14.7mpg and saw up to 17.6mpg when running just the Atlas 40 FICM tune.
Next step is the lift, wheels, and tires. Definitely need the tires soon. I don't think mine are going to last long.
CJR305 is offline
post #2 of 4 Old 06-26-2014, 10:15 AM Thread Starter
One of the 4 loads I hauled on Monday. All were around the same weight.
Big load from today. Trailer is full with heavy cable pulling gear that we use for work.
Next to my dad's F150 Ecoboost Platinum
CJR305 is offline
post #3 of 4 Old 06-26-2014, 10:46 AM
colonel angus's Avatar
Quoted: 2 Post(s)
I wouldn't go more than max 4" and 35's. Past that mark and you'll likely double the cost and double the reduction in MPG lost.
D
2005 CC SB 147K
MTW MaDmAx 68mm VGT
Warren Diesel 175/75's Super Spools N Drew's Tunes
VXCF9CA TQCI1NB
SCT A101706100004F6C
VIN FTSW21P65EB08535
ARP's - MBRP T-Back Kitty Del.
ICON 4.5" + 2" Spacer
Mickey T's Baja ATZ P3 37's
METHOD Racing Wheels 20x
ScanGauge II / RedHead Box
Snow Perf. Stg. II W/ Banks Intercooler
Bulletproof EGR Del. & External Filter
ELC Coolant & Sin. Coolant Filter
AMP Steps & ARE Cover W/ Bed Slide
colonel angus is offline
post #4 of 4 Old 06-26-2014, 10:55 AM Thread Starter
D
Thats exactly the setup I am going to get. BDS 4" and 35" Nitto Terra Grapplers.
CJR305 is offline
