looking for tne right clutch - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-25-2014, 02:38 PM Thread Starter
I have an '03 6.0. I just had the ARP head studs, Black Diamond head gaskets, EGR delete and a 5" straight through exhaust upgrades done. I plan on a K&N or Airaid intake. I'd like to know how many horse power I gain, if any, with these upgrades to get the proper clutch. Any help with this would be great.
6stoner0 is offline
post #2 of 8 Old 06-25-2014, 02:43 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
HP gain with those mods, maybe 10-15hp if your lucky.
"Rich is really good with knobs, his soft touch and attention to detail are like no other."-Portcity_gt
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 8 Old 06-25-2014, 03:05 PM Thread Starter
Thanks for the help!
6stoner0 is offline
post #4 of 8 Old 06-25-2014, 04:52 PM Thread Starter
out of curiosity, how much boost psi does the 6.0 have
6stoner0 is offline
post #5 of 8 Old 06-26-2014, 01:38 AM
Real Men of Genius
Super Diesel's Avatar
Quoted: 10 Post(s)
Feedback Score: 9 reviews
Are you sticking with the stock tune/programming? If so, then a SB 1950-60DFK will be more than enough.
Chris | 2005 F-250 RCSB | "Ranger - Turbo Diesel V8"
CED Compounds - Conventionals - Supporting Mods
Super Diesel is offline
post #6 of 8 Old 06-26-2014, 03:06 PM Thread Starter
thinking maybe a SCT programmer. I was told by the folks at S.B. I don't want to over clutch. where's the happy spot between my few upgrades and with all the choices of a programmer?
6stoner0 is offline
post #7 of 8 Old 06-26-2014, 06:31 PM
Real Men of Genius
Quoted: 10 Post(s)
It all depends on how much horsepower you want to end up with.
Here's what Southbend has to offer:
1950-60OKHD - Stock hp & torque heavy duty solid flywheel replacement
1950-60DFK - 400 hp, 800 ft. lbs. of torque for 6.0
1950-60CBK - 475 hp, 1000 ft. lbs. of torque for 6.0
SFDD3250-60 - 500-700 hp, street dual disc, NOT FOR COMPETITION USE
The last one is a dual disc clutch, all the others are single disc. If you don't plan on upgrading the turbo and/or injectors, then the 1950-60CBK would probably be what I'd get. Most tuners have aggressive tunes for studded trucks that push 450rwhp on stock turbos and injectors.
post #8 of 8 Old 06-27-2014, 04:19 AM
william_ace's Avatar
Quoted: 2 Post(s)
I've got the SFDD3250-60 - 500-700 hp, street dual disc, NOT FOR COMPETITION USE clutch.
You will upgrade for more power I'm guessing so this is the route I would go.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
