banks 6.0 turbo - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 06-23-2014, 06:16 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
banks 6.0 turbo
In the latest issue of Diesel Power they installed the Banks 6.0 powermax turbo. (this along with the banks tuner,water/methanol system,exhaust and intercooler).
I was just wondering is there anything special about the banks turbo? Does anybody run one? Any thoughts one way or another about this turbo?
And yes I know Banks is not the most popular on here, Im just trying to look around before I go droppin the kids college fund on a turbo.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #2 of 11 Old 06-23-2014, 06:40 AM
shenanigans
junior125's Avatar
Quoted: 1506 Post(s)
Garage
you talking this one??
Banks Power | 03-07 Ford - 6.0L Power Stroke>>Garrett Turbocharger
Mike
2005 CCSB F250 4X4
O-ringed with H-11's, Irate T4, BW S363SX-E, Holders 175/30%, ODAWG S3R, TSD Tunes, No Limit Intake, CSF Intercooler, BPD Remote Oil Cooler, BPD water pump, 7.3 Fan Adapter, BD Diesel Manifolds, 6.7 Pump, Driven Diesel RR, Built Trans w/ PI converter, Derale Deep Pan, Traction bars, AirLift Helper Bags
junior125 is offline
post #3 of 11 Old 06-23-2014, 06:47 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
Ya that be the one.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 11 Old 06-23-2014, 06:49 AM
shenanigans
junior125's Avatar
Garage
Its the exact same as a regular p-max, it would be better to just get a stage 1 or 2 from any reputable builders
Mike
2005 CCSB F250 4X4
post #5 of 11 Old 06-23-2014, 06:55 AM Thread Starter
kinnisoj's Avatar
Quoted: 2 Post(s)
reeeeeeeley......hmmm thanks. I need one of those books for dummies on turbos....
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 11 Old 06-23-2014, 07:10 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
Yep, just a regular Powermax. IF you get a powermax, I HIGHLY recommend getting a billet wheel for it. They are pretty much garbage without one.
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #7 of 11 Old 06-23-2014, 07:15 AM
shenanigans
junior125's Avatar
Garage
Nate can get you a DIY 2.5 kit seen as you have an 03 turbo
Mike
2005 CCSB F250 4X4
post #8 of 11 Old 06-23-2014, 08:20 AM
Quoted: 8 Post(s)
What these guys said. I've been reading your other thread and IMO you'd be best served by hitting up one of the Vendors and picking up a Stage 1 with the 13 blade turbine side. With what I've read about you towing and your current EGT problems I think that would fit perfectly. You mentioned being concerned about losing your "'03 whistle" in your other thread, with the 13 blade turbine you will lose that but you will gain faster spool up. Given your elevation, EGTs, and propensity to tow I feel that's a rewarding trade off.
2005 Excursion Lariat 4x4
Mishimoto coolant filter, RCD EGR delete, '03 turbo w/ single plane billet compressor wheel, Edge CTS w/ EGT probe, 5" Rough County suspension, Hellwig 32mm sway bar, 35x12.50 Toyo M/T, 20x12 Fuel Renegade D263 wheels
Originally Posted by F450Harley View Post
I really believe these trucks have adaptive behaviors to your driving habits. Your truck reflects you.
If you think your truck might let you down…………..it WILL.
6literdiesel is offline
post #9 of 11 Old 06-23-2014, 09:13 AM
XL trash...
Merc82's Avatar
Quoted: 291 Post(s)
Yup. I agree with you there.
Uhh.. Nate, about your SIG... What's a "KC Turo"
Gadgetguru likes this.
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #10 of 11 Old 06-23-2014, 10:18 AM
Heavy_GD's Avatar
Quoted: 1440 Post(s)
Feedback Score: 3 reviews
what ever it is, I'm pretty sure its not a modified power max hahahahha.
GD
Originally Posted by 6.0Stroker View Post
It's Toren. .. don't question it ..
Heavy_GD is online now
