Suggestions on my build - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 69 Old 06-22-2014, 07:04 PM Thread Starter
Hey guys iv picked up a 2004 f250 cc/sb 6speed as of now iv ordered exhaust cai sct ts 190/100 injectors rr kit kc stage 3 turbo stage 3 ported intake ad 165 water/meth injection riffraff boots pusher intake horn new intercooler tubes coolant filter sb dual disk clutch will be getting manifolds and and up pipes as we'll there's a few other odds and ins but I just wanted y'all's opinion if I was needing anything else iv just about hit my spending limit iv got a little left I can spend about 2k but iv racked my head on if I need anything else so if y'all know of something that will help me out all info is welcomed thanks a ton
Yeeyee87 is offline
post #2 of 69 Old 06-22-2014, 07:10 PM
william_ace's Avatar
Quoted: 2 Post(s)
You've done just about everything I have!! Who's turbo and intake did you go with?
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #3 of 69 Old 06-22-2014, 07:27 PM Thread Starter
It was a toss up but I ended up getting kc turbo and wpe intake Nate was very helpful and answered ever text I sent him very stand up guy I went with holders injectors I see that's what your running how do you like them
Yeeyee87 is offline
post #4 of 69 Old 06-22-2014, 07:28 PM Thread Starter
Oh and the truck has studs by the way sorry forgot that
Yeeyee87 is offline
post #5 of 69 Old 06-22-2014, 07:42 PM
Making ported intakes
ODAWG714's Avatar
Quoted: 6 Post(s)
I would do a wpe ported intake. Change the riffraf intake horn to a no limit fab and steed speed is going to come out with a stock style output exhaust manifold. Coming here very soon to bolt up to stock style up pipes
Oliver
6.0/6.4 Ported intake manifolds, turbos, air intakes, fuel systems and much much more!!!!
ODAWG714 is offline
post #6 of 69 Old 06-22-2014, 07:43 PM
ODAWG714's Avatar
Quoted: 6 Post(s)
Guess I didn't read the whole thing haha
najaf4life likes this.
Oliver
ODAWG714 is offline
post #7 of 69 Old 06-22-2014, 07:49 PM Thread Starter
Hahaha ya I got the pusher intake and stock ic tubes because the man I got it from had the water/meth put on with the head studs and they hacked up the ones on it or I would of probably just left the stock horn on I love the no limit stuff but I was trying to save a little where I could
Yeeyee87 is offline
post #8 of 69 Old 06-22-2014, 07:51 PM Thread Starter
And I'll look into the steed speeds I got busy with all the other stuff and missed out on a good deal on steeds and up pipes I was pretty upset with myself hahaha
Yeeyee87 is offline
post #9 of 69 Old 06-22-2014, 08:16 PM
peixinho's Avatar
Quoted: 199 Post(s)
What size tires?
Any lift?
If you have 35s or larger then I would invest in gears
Maybe a bigger intercooler
Sounds like it is going to be an awesome build
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #10 of 69 Old 06-22-2014, 08:30 PM Thread Starter
As of now it's leveled with 35x12.50x20's but the tires are about 30% I got the stuff off a buddy for almost nothing it beats the stock look till I get new wheels and lift but I'll be running 37x13.50x20's with a 6 to 8" lift iv been looking at gears but not sure what I will go with I will probably wait till I figure out if I for sure want to lift it and ya iv been looking at an intercooler but wasn't sure if I needed one for sure I was going to run the stock one and dyno then probably invest in an aftermarket and dyno again thanks peixinho I can't wait to get her done and see the outcome
Yeeyee87 is offline
