Guys with Powermax turbos - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 23 Old 06-22-2014, 01:25 PM Thread Starter
Quoted: 2 Post(s)
Question Guys with Powermax turbos
I don't want to name the turbo builder or the tune writer because I truly don't believe there is anything wrong with their products and don't want to turn anybody away from them.
With that said, I recently bought the equivalent of a powermax with a billet wheel and had my "hot street" tune updated to match the new turbo. I knew to expect a little more lag which it definitely had, but the updated tune helped a lot and when it lights it gets to 29lbs on my livewire quickly and pulls hard.
My issue is smoke. I have to drive like I have an egg on the pedal to keep from leaving a trail of smoke until the turbo lights. If I get locked up at 55-65 or so it's d@mn near impossible to accelerate with out smokin everybody out.
I'm pretty confident that I've got everything sealed up, but I'm going to check again when I get a chance. Just curious what y'all have experienced with these turbos. I don't mind blowin a little smoke when I'm nailing it, just don't care to see any on my normal drive to work.
Thanks for reading. You guys are a great support group when I'm feeling frustrated with my 6.0
2007 F250 Lariat FX4 CCSB
200,000+ Miles
SCT Livewire TS
Innovative Xtreme Street
Barder Stg 1.5
Arp Studs, Sinister EGR Delete
cudakid03 is offline
post #2 of 23 Old 06-22-2014, 01:30 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I would think that if your getting 29 lbs you've got things sealed up. Id kill for that kinda boost.
Have you talked to the tune writer and told them what you have going on?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 23 Old 06-22-2014, 01:39 PM Thread Starter
Quoted: 2 Post(s)
I have not talked to him since I got this first revision. I guess I just wanted to know if I was expecting too much out of this setup.
200,000+ Miles
SCT Livewire TS
Barder Stg 1.5
post #4 of 23 Old 06-22-2014, 01:57 PM
strokersixo's Avatar
Quoted: 32 Post(s)
I have a pmax turbo and only smokes when I do a WOT run, but under normal not a trace of it.
I run SPD tune by TSD and runs like a champ.
Black smoke is unburned fuel, talk to your tune writer, and check your intake filter.
Sent from tapatalk PRO ........ I WISH
--MAX--
strokersixo is offline
post #5 of 23 Old 06-22-2014, 02:02 PM Thread Starter
Quoted: 2 Post(s)
Thank you that's what I wanted to know. Running a factory filter that was changed probably 3000 miles ago.
200,000+ Miles
SCT Livewire TS
Barder Stg 1.5
post #6 of 23 Old 06-22-2014, 02:25 PM
Quoted: 32 Post(s)
sure thing,
Filter then is good not sure when mine was changed but looks clean, then it's your tune. Check out spd if you're studded or drew street king tune deliver good results, but love my spd.
What tune are you running?
--MAX--
post #7 of 23 Old 06-22-2014, 02:36 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
What kind of smoke? Sounds like maybe a seal is gone in the turbo did you have the turbo balanced or rebuilt? Do you have any oil in the compressor housing of the turbo? Can you loosen the down pipe and check for fuel or oil on the turbine side? Maybe an injector is sticking. Once the turbo lights does it still smoke?
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #8 of 23 Old 06-22-2014, 02:41 PM
Do you have stock injectors?
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #9 of 23 Old 06-22-2014, 02:48 PM Thread Starter
Quoted: 2 Post(s)
It's black (fuel) smoke not blue (oil). Turbo was built and balanced from new powermax. The smoke will clean up once the turbo lights and it idles and cruises clean.
200,000+ Miles
SCT Livewire TS
Barder Stg 1.5
post #10 of 23 Old 06-22-2014, 02:51 PM Thread Starter
Quoted: 2 Post(s)
Yes, stock injectors.
200,000+ Miles
SCT Livewire TS
Barder Stg 1.5
Tags
powermax , smoke
