Looney tune and FICM tune?? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-22-2014, 07:54 AM Thread Starter
Hi all, recently had to replace my FICM and the unit I bought from a guy I was told had a 100hp tune on it. I was told there would be no problems with the tune and FICM tune and there hasnt been. Truck is studded and deleted for background reference. Now the only thing I have noticed is that when I really get on it, I am only making a little over 20lbs boost compared to before when I would bump along the red line in the boost guage. Thoughts? Should I get the FICM reflashed to stock? Am I just ok to run it? Any answers would be helpful!
acydzik is offline
post #2 of 9 Old 06-22-2014, 08:29 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
If you are reading boost via map sensor then it is probably your tune. There are some variables to the boost reading from the Ecu, I bet if you put a sensor on your intake hooked it to manual gauge your readings would be spot on. Another way to know if it is your tune is remove the tune go back to stock and see what read. I would not get wrapped up around boost readings unless there was a problem. If you had a boost leak you would know it, the truck would lack power or make some odd sounds.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #3 of 9 Old 06-22-2014, 08:34 AM
Pro fuzz's Avatar
Quoted: 29 Post(s)
What are the EGT readings ? That's what u need to be watching !
2006 F350 KR cclb 155/stock full force powermax / WWII leveled carli 2.5 pintops 08&up full rear spring ouo 3link arms 36 toyo mt 4.30 yukon grizzly rear locker :yike
s:
New ride 2015 tow boss dpf & egr lost !!
Pro fuzz is online now
post #4 of 9 Old 06-22-2014, 09:46 AM Thread Starter
No egt guage, just looking to get some opinions
acydzik is offline
post #5 of 9 Old 06-22-2014, 09:46 AM Thread Starter
Will be getting one soon
acydzik is offline
post #6 of 9 Old 06-22-2014, 09:53 AM
Pro fuzz's Avatar
Quoted: 29 Post(s)
That should be the first thing on your list !! The herc 100 is know to run HOT !!!
s:
post #7 of 9 Old 06-22-2014, 10:13 AM Thread Starter
Is that the tune from php?
acydzik is offline
post #8 of 9 Old 06-22-2014, 10:13 AM Thread Starter
I bought it used so I have limited info. It was rebuilt by ficmrepair.com
acydzik is offline
post #9 of 9 Old 06-22-2014, 01:22 PM
Agreed php Hercules runs hot if you get on it and if you look on their website they strongly recommend monitoring egts. This is really critical when towing. Do you have a stock exhaust and turbo? If you do I would not get on her often, could melt the turbo turbine.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
