Interccoler effects on IAT testing video - Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By jetjock15
  • 1 Post By bondajb
  • 1 Post By peixinho
post #1 of 10 Old 06-22-2014, 05:09 AM Thread Starter
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 105 Post(s)
Feedback Score: 3 reviews
Here's the video. Post up your questions.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
The Following 4 Users Say Thank You to HeavyAssault For This Useful Post:
Merc82 (06-23-2014), Oilylizard (06-23-2014), peixinho (06-22-2014), william_ace (06-22-2014)
post #2 of 10 Old 06-22-2014, 07:56 AM
jetjock15's Avatar
Quoted: 113 Post(s)
Can you post a synopsis of results as you observed them. I will attempt to watch all 17 min but a synopsis would be appreciated. Looks like some real works testing and documentation, love those tests and posts - much Appreciated Brian
HeavyAssault likes this.
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #3 of 10 Old 06-22-2014, 08:21 AM
bondajb's Avatar
I am surprised how little ait 2 varied. .it constantly climbed..... My guess is ambient was 96.. amazing how much heat the truck inhales at > 10 mph.
I would like a little clarification on pids.. the glare made it hard to see and I could not read what pid monitored what..
Pro fuzz likes this.
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #4 of 10 Old 06-22-2014, 09:20 AM Thread Starter
N.S.D.Q.
Quoted: 105 Post(s)
OAT wasn't a PID that I was able to find in the AE menu. For the record the EATC inside the truck showed OAT was between 90-95*F thru my driving. I'm comfortable saying the temps were in the 90's for the testing.
Settings Left to Right; Top row to Bottom row:
Baro// IAT1// IAT2
Vehicle Speed// MAF// Manifold Pressure (boost)
ECT// EOT// EBP
Remember the OAT was over 90*. I wanted to demonstrate the daily driving/stop-n-go one might most commonly encounter. I need to get a larger capacity SD card to show the temps during HWY driving.
--This is one of the few times I have used AE. Some of the readings are/were expected while others gave me some things to research. While AE gives a TON of PIDs to monitor these were the ones I felt were suited for the demonstration.
--The Baro seemed to change while driving which I didn't expect to see. It might be a result of using the AE.
--EBP is reading absolute so you need to subtract at least 14.5 PSI from the reading to show actual EBP.
--IAT2 was higher than I expected to see. I do have some theories as to why that temperature seems so high compared to IAT1 and OAT. The temp did seemed to settle in after a bit of driving at over 165*F.
My thoughts:
A) Possibly the IC interior and exterior need to be cleaned. I ran the CCV for awhile before doing the CCV delete. I can easily pressure wash/degrease the exterior but the internal cleaning will have to come later.
B) Running the billet single plane compressor wheel may cause the IAT to rise due to the increase flow and compression of air.
C) Radiator and IC proximity to one another causing radiant heat transfer. Maybe but I'd say unlikely considering the IC is in front of the radiator. Another Idea: This radiant heat transfer may play a bigger part when the truck isn't moving. So the radiator radiant heat could be causing the aluminum IC to be heat soaked and not as effective.
An interesting note: Towards the end I was thinking about the IAT temp. I happen to have an handheld IR thermostat so I wanted to check the intake manifold surface temps. As expected the areas closest to the intake elbow were close to the readings off the AE. I began to wonder if the IAT2 sensor was getting heat soaked from the GOGO manifold covers.
--Link below for the Sentry ST660. +/-3*F for the range I was using.
ST660,ST662,ST663 Infrared Thermometer SENTRY-Infrared Thermometer-ShangHai,China
So unless you take the time to find YOUR real world information before and after you cannot say what has changed.
post #5 of 10 Old 06-22-2014, 09:47 AM Thread Starter
N.S.D.Q.
Quoted: 105 Post(s)
This is what my intake housing looks like since I've cut it down. It's cut down even more now then when I took this picture.
post #6 of 10 Old 06-23-2014, 04:59 AM
XL trash...
Merc82's Avatar
Quoted: 289 Post(s)
Heavy, what intercooler are you running?
Chris... LBCC dirty old XL with some special sauce.
Sent from a boat in the middle of a swamp....far away from humanity as possible....
Merc82 is offline
post #7 of 10 Old 06-23-2014, 05:18 AM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Great video, for my clarification, IAT1 is air temp when it first comes into the air filter and IAT2 is after it has traveled through the entire intercooler?
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #8 of 10 Old 06-23-2014, 08:41 AM
peixinho's Avatar
Quoted: 193 Post(s)
I did not think it was high at all... actually it seemed to be a little low at some points and slow to respond. I think people would be very surprised to hear how hot things are after coming out of the turbo. The intercooler does help to cool it down but it can only be so efficient. Also your intercooler will be more efficient at higher speeds because it needs lots of air flow to do its job.
Here is an example:
making 35 psi of boost
Outside air temps = 100
Inlet air temps = 102
Turbo outlet temps = 450
intercooler efficiency = 75% (which is pretty good)
Intercooler out temps = 190
Here is another example:
making 10 psi of boost
Turbo outlet temps = 250
Intercooler out temps = 140
Those are just a couple of examples that are pretty generalized. There are a lot of things that can affect those numbers which include... speed, intercooler efficiency, compressor efficiency, elevation, heat soak, etc...
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #9 of 10 Old 06-23-2014, 03:50 PM Thread Starter
N.S.D.Q.
Quoted: 105 Post(s)
Spearco for the win...
post #10 of 10 Old 06-23-2014, 03:51 PM Thread Starter
N.S.D.Q.
Quoted: 105 Post(s)
Correct. For my 2006 the IAT1 is pulled using the MAF sensor. IAT2 sensor is on the driver's side runner of the intake manifold about 3-4" at most from the intake elbow.
