6.0 low pitched whistle - Ford Powerstroke Diesel Forum
Old 01-13-2009, 06:59 PM
hey wondering if any one has had this issue. truck makes a low pitched whistle under a load or letting off the gas quick after punching it. not constant it fades in and out thanks for the help
Old 01-13-2009, 07:02 PM
it just the turbo winding down if i read correctly
Old 01-13-2009, 07:06 PM
Does it sound like a tea kettle??.... Then it is your degas bottle and its either head gaskets or egr causing it
Old 01-13-2009, 07:15 PM
whistle
yeah its seems to make it more with the bigger tunes and i just had some coolant coming out of the bottle. but it doesnt get loud like a tea kettle
Send a message via AIM to foursixtysix
I think I know what noise you're talking about my 6.0 did the same thing...I've heard it compared to a tea kettle which is most like it. In all that I have read it all goes back to head gaskets failing. The noise comes from the degas bottle cap, and with mine I bought a new cap because in a few cases I read about the cap having an issue, and that solved the problem for a while but the droned out whistle returned sadly. So how many miles are on your truck? If it is within warranty I'd be scheduling a date with the dealer...
EDIT - Someone beat me to it
I have an 06 that has done this twice this week. I'm guessing it's coming from my turbo, or possibly a leak in the turbo outlet pipe causing the whistle sound (Maybe a crack in my pipe, or the tube is loose). Going to check into it more on the weekend if it keeps doing it. Can't see it being a head gasket or egr issue unless it's puking coolant, which mine isn't.
Old 01-13-2009, 07:19 PM
Mine didn puke either because i ran my coolant so low.... but it was both my egr and gaskets
Old 01-13-2009, 07:20 PM
yeah i think your right about the head gaskets never used to make it with big tunes just puked a little coolant now all of a sudden makes this sound truck has 70k on it
Old 01-13-2009, 07:24 PM
Was it overheating when this happened?
Ya mine had 60k on it (Looneytuned for 55k) Now i studded and no more egr system.. Life is good now
