My next step - Ford Powerstroke Diesel Forum
post #1 of 28 Old 01-13-2009, 02:20 PM Thread Starter
DuraWhat?'s Avatar
My next step
Okay I know everyone on here is probably getting tired of seeing repeated post of what mods to do, but im stuck. Currently I have tunes, egr delete, 4” straight pipe turbo back, K&N stage 2, Airad power elbow with deleted actuator, coolant filtration system, im all set on the gauges, most of the free do it your selfers like zoodad, and line lockers. So, with that said where do you guys think I should go next fuel system, turbo??? I need some ideas. I don’t have studs nor do I plan on getting them till I need them, but I do have a fuel return kit to install when the heads do go. I also plan on upgrading the heads and gaskets at that time, so for now any ideas? Thanks for the help.
Director: Peachstate Powerstrokes Association
Ross
Replacement Windows, Doors, and Garage Doors
DuraWhat? is offline
post #2 of 28 Old 01-13-2009, 02:23 PM
zippy557's Avatar
fuel system oil bypass ...
-Dave
'07 F250 FX4 Supercab SB
X3 ID Custom Tunes, ARP Headstuds, S&B Intake, ITP Reg Return Kit, PHP Atlas 80 tuned FICM, Isspro Performax - Coolant, Fuel Pres, Trans and Egt, 4" Turbo Back Straight Pipe, Zoodad Mod, Harley Head Lights, Recon Smoked Cab & Mirror Lights, White Night Back Up Light
zippy557 is offline
post #3 of 28 Old 01-13-2009, 02:35 PM Thread Starter
DuraWhat?'s Avatar
yeah,I could the oil by pass. Any recommendations on that
Ross
post #4 of 28 Old 01-13-2009, 02:38 PM
zippy557's Avatar
when i was looking i found a lot of people say OilGuards system is the way to go
-Dave
zippy557 is offline
post #5 of 28 Old 01-13-2009, 02:43 PM
Raul@Stealth Automotive's Avatar
your next mod should be studs.... it will help with future mods
Raul@Stealth Automotive is offline
post #6 of 28 Old 01-13-2009, 03:37 PM
tex25025's Avatar
Studs, fuel system, injectors, turbo
Unless your going to be going well over 500 hp, you'll won't need to mess with the headache of a/m head gaskets.
2006 6.0 King Ranch DRW
Spartan Stage 1 Towing Injectors
Headstuds
Beta Spartan Phalanx
Suncoast Heavy Duty Torqshift Rebuild
ITP Fuel Regulated Return
Straight Piped MBRP 5" Exhaust
64mm Non-VGT turbo
tex25025 is offline
post #7 of 28 Old 01-14-2009, 05:51 AM Thread Starter
DuraWhat?'s Avatar
Yeah, but while im in there I might as well do it correctly, I was considering fire rings and heads when the time comes; and who knows maybe one day I will decide to go above 500 and do more internal work.
Ross
post #8 of 28 Old 01-14-2009, 05:56 AM
Goose350's Avatar
Do you have a programmer?
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #9 of 28 Old 01-14-2009, 06:16 AM
tex25025's Avatar
In that case be sure to take your time. A/M gaskets require everything to be damn near perfect on the install.
Headstuds
64mm Non-VGT turbo
tex25025 is offline
post #10 of 28 Old 01-15-2009, 05:25 AM Thread Starter
DuraWhat?'s Avatar
oh yeah, Im good for know on the programmer. I seen a thread talking about what a Pain the heads ended up being for someone else. On the plus side my father-in-law owns a machine shop so simply tweaking a can get covered.
Ross
