Up-pipes, heat shields, and wraps - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By windrunner408
post #1 of 10 Old 06-19-2014, 10:58 AM Thread Starter
Ok gonna wrap my up pipe (I know ceramics are better), was hoping if I did this if I could get rid of the heat sheilds on them.
Anyone have any luck getting rid of various heat shields and what was required to accomplish this. Thanks.
Quint is offline
post #2 of 10 Old 06-19-2014, 11:18 AM
strokin6L's Avatar
Quoted: 4 Post(s)
I wrapped mine and use no heat shields.
2004 F-350 SC 4x4, XLT, 4" dual Magnaflow, AFE intake, No Limit piping, spearco intercooler, water injection, ARP studs, hypemax o-ringed heads, SCT tuned by Innovative Diesel, tuned FICM, Hellman's sump, FASS, Fuelab, regulated return, 190/75 injectors, KC/MTW 68 w/.72ar, suncoast trans w/billet input, edge insight CS with dakota digital gauges, amsoil by-pass, BD exhaust manifolds
strokin6L is offline
post #3 of 10 Old 06-19-2014, 11:34 AM
BACKYARDIGAN
windrunner408's Avatar
Quoted: 4 Post(s)
I don't wrap mine nor do I use heat shields...
Nate
2006 F350 (BACKYARDIGAN) - 67mm Turbo, 215/85 injectors, WPE intake manifold, NB/Warren Trans, and more stuff that I don't care to mention....
2006 F250 (LITTLE DURTY) - WPE Manifold, Up-pipes, EGR delete kit, and Tuned By ME
BULLET PROOF DIESEL 1-888-967-6653
KC TUROS - Not just a modified Powermax...
WINDRUNNER PERFORMANCE ENGINEERING
windrunner408 is offline
post #4 of 10 Old 06-19-2014, 12:07 PM
peixinho's Avatar
Quoted: 231 Post(s)
IMO... I would ceramic coat, wrap, and keep all the heat shields... Why not
Theoretically it should keep down engine bay temps, increase spool up, and looks cool
KC Turbos
Warren Diesel Dealer
My Current Build Thread
Current Setup 190/30 and KC 64mm Stage 2 turbo
peixinho is offline
post #5 of 10 Old 06-19-2014, 12:11 PM
BACKYARDIGAN
Quoted: 4 Post(s)
Originally Posted by peixinho View Post
IMO... I would ... keep all the heat shields... Why not
Because heat shields are a PAIN IN THE ARSE when it comes to working on stuff. JMO, but I think you can acheive all you want to with ceramic coating and heat wrap.
peixinho likes this.
Nate
post #6 of 10 Old 06-19-2014, 12:12 PM
peixinho's Avatar
Quoted: 231 Post(s)
Tell that to the fire I started a few weeks ago
KC Turbos
peixinho is offline
post #7 of 10 Old 06-19-2014, 12:14 PM
BACKYARDIGAN
Quoted: 4 Post(s)
You know air makes an EXCELLENT insulator... Probably the best one in fact.... It helps when you have adequate space between stuff...
Nate
post #8 of 10 Old 06-19-2014, 03:13 PM Thread Starter
Thanks for the entertaining help guys. Personally I hate heat shields but sometimes they are necessary.
Quint is offline
post #9 of 10 Old 06-20-2014, 02:14 AM
ccdemo71's Avatar
Mine are naked as well. No wrap or shields.
07 F-250 Lariat CC/SB 4x4
4" turbo back straight pipe no cat
SCT SF3 with Gearhead tunes
ARP headstuds
Black Diamond Gaskets
EGR delete
Odawg Ported Intake
Warren 175/30 injectors
Barder stage 2.5
Regulated return
ccdemo71 is offline
post #10 of 10 Old 06-21-2014, 11:04 AM
Wrap and no shield here. No issues.
Nov 2003 built
2004 PSD F250.
SC Long Bed SRW
EGR delete, Studs, Swamps FICM, 4" turbo back
lightninmike is offline
