Finally putting engine together. - Ford Powerstroke Diesel Forum
 12Likes
post #1 of 17 Old 06-18-2014, 04:42 PM Thread Starter
Finally getting it together after a couple hick ups with push rod length and spring coil bind. Also adding coolant return lines from the back of the heads. Adding a dual bypass filter setup. Making my own regulated fuel return, trying to keep everything out of the way and I didn't like any of the stuff that was out there for sale. More pics to follow. Last pic is for the oil supply to the bypass filters.
ID:	300961   Click image for larger version
ID:	300969   Click image for larger version
ID:	300977   Click image for larger version
Diesel Equipment service manager lead technician
jpott62 is offline
post #2 of 17 Old 06-18-2014, 04:57 PM
powerstrokecrzy's Avatar
Quoted: 264 Post(s)
Looks good.
All that work and no ported/powder coated intake mani?
bgraiders323 likes this.
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #3 of 17 Old 06-18-2014, 05:01 PM Thread Starter
Still working on the intake. Heads are ported comp cams springs. Trying to get some of the other loose ends wrapped up at the same time.
jpott62 is offline
post #4 of 17 Old 07-26-2014, 05:57 PM Thread Starter
Engine went in, wrapping up my regulated fuel return. Again I didn't want hoses everywhere under the hood so I came up with this setup. It's 5/16 brake line silver soldered into banjo fittings and it runs to -6 hose to the pressure regulator on the frame and back to the return fitting on the stock hfcm.
ID:	316578   Click image for larger version
jpott62 is offline
post #5 of 17 Old 07-26-2014, 06:06 PM
Thats pretty bada$$!!!
Maybe you can make some extra Reg Ret kits and accept donations?>??
bgraiders323 is offline
post #6 of 17 Old 07-26-2014, 06:15 PM Thread Starter
I would need a spare engine to get the line bent properly that goes from head to head but it could be done. I have a spare at work.
jpott62 is offline
post #7 of 17 Old 07-26-2014, 06:19 PM
Donations???
Anymore pics of the Reg Ret from the top side???
post #8 of 17 Old 07-26-2014, 07:20 PM Thread Starter
Nothing to really see from up top. Here's another pic from the front.
jpott62 is offline
The Following User Says Thank You to jpott62 For This Useful Post:
mossyoak (07-27-2014)
post #9 of 17 Old 07-28-2014, 06:10 PM Thread Starter
Some pics of the diy ceramic coating I did on the exhaust manifolds and uppipes.
ID:	317338   Click image for larger version
jpott62 is offline
post #10 of 17 Old 08-26-2014, 06:49 PM Thread Starter
It's finally alive, finished everything up tonight. Set the fuel pressure on the regulator at 62 psi. Let it run in the shop about an hour checking for leaks, nothing found. Oil bypass filter system is good. Coolant lines no problems. Best part is no leaks on my regulated return. Took it out for a short drive. It's still all stock other than the cam. Seems to spool the turbo quicker than most stock trucks I've driven. It does have a completely stock 03 turbo on it. Need to get more miles on it then think about some tuning. That will have to wait till after my bear hunt on the 12th, I have a 12 hour drive planned for if soon.
sealeveloc likes this.
jpott62 is offline
