fuel pump question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-17-2014, 02:11 PM Thread Starter
ccdemo71's Avatar
fuel pump question
OK guys I'm running 175/30 warren injectors and a regulated return on stock pump. My fuel pressure is good until about 40-50% throttle. At that point it is dropping to around 40 psi and at wot it is around 20 psi. My question is will a new stock pump help? I want to do a a1000 or fuelab with sump and bowl delete but my wife is not going to go for me spending another $1000 right now so guys with these or larger injectors does a new stock pump keep up or at least come close? Also do I need to get a motor craft or has anyone tried the cheaper ones the parts stores carry? Want to spend as little as possible as it is just a temporary fix until wife settles down a little and I can get the goodies.
07 F-250 Lariat CC/SB 4x4
4" turbo back straight pipe no cat
SCT SF3 with Gearhead tunes
ARP headstuds
Black Diamond Gaskets
EGR delete
Odawg Ported Intake
Warren 175/30 injectors
Barder stage 2.5
Regulated return
ccdemo71 is offline
post #2 of 7 Old 06-17-2014, 02:18 PM
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
Maybe try a sump now or even the 6.4 pump feeding the 6.0 pump
MrOneEyedBoh is online now
post #3 of 7 Old 06-17-2014, 04:51 PM Thread Starter
ccdemo71's Avatar
I will probably go ahead and put a sump on before In case its the draw straw that is the problem wether its plugged or whatever but I still think my pump might be weak. This winter it struggled quite a bit but with warmer temps it has been ok just not what I think it should be.
ARP headstuds
EGR delete
Odawg Ported Intake
Barder stage 2.5
Regulated return
ccdemo71 is offline
post #4 of 7 Old 06-17-2014, 09:13 PM
brscott38's Avatar
Look into the 6.7 pump you already have the rr. You can find the 6.7 pumps a lot cheaper than a1000 setup it flows and filters extremely well. This is the route I will go just a couple things to finish before starting another project.
brscott38 is offline
post #5 of 7 Old 06-18-2014, 02:29 AM
Quoted: 13 Post(s)
The 6.7 isn't proven yet. Sure people are doing it, but I wouldn't say longevity is there just yet on our trucks.
post #6 of 7 Old 06-18-2014, 04:15 AM
bondajb's Avatar
Read the 6.4 pump right up.. a few are having similar issues. .mine was running exactly like yours.. problem solved!!
Aaron 2005 f250 552/1040 45k miles
S&B. 4" mbrp, Arp's, Dual oil bypass. CCV fltr, Clnt fltr Mag trans pan 08 diff cover. 4.10's, 315's MotoMetal 951 & 5" lift.TGC trac bar, Bislstien Shocks & Dual stear stabilizer. B&W . Air Rides. Snows MPG Max. Edge Insight, fuel sens. DC Eng.185 alt. 58v ficm 6.4 Juger pump Fass sump
NO more mtw turbo
AJB Custom R.R.
AJB Custom y pipe
AJB P&P Intake
PHP Gryphon
Banks IC
BARDER Stg2
Warrens 175/30
P.I. T.C & input.
Flight Fab. Track bars
bondajb is offline
post #7 of 7 Old 06-18-2014, 07:14 PM
brscott38's Avatar
What do you think the down fall/weakness to the 6.7 pump would be?
