'03 vs '06 engine controler
I have a ’03 f-250 with a ’06 6.0l and I want to get an egr delete kit but I don’t want to deal with the error codes right now. I was told that a ’03 engine controller won’t through the codes and no other ill affects if the egr is just unplugged. Now will the old ’03 controller work on the ’06 or should I just wait and do the egr kit with a controller that will fix it?
i have an january build 2003 6.0l and i trashed my ecm i took an 05 excursion ecm and it did great in fact it hade the codes to eliminate the BP sensor and a fue other things so i guess it would work the other way round i kinda like the 05 ecm it had all the new fimweare in it solved alot of thr surging and fuel consumption issues i recomend staying with the 05
Make your life simple, EGR delete kit, and a SCT. Thats all you need.
ya at the time thay didne have what i needed and it was under warrenty
