EDGE CS MONITORING HELP!!! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 06-14-2014, 01:03 PM Thread Starter
i have an 05 f350 king ranch, i just recently had a bad egr vavle, and needless to say it sucked, so i have the egr delete going in along with a brand new sct tuner and custom tune to for egr. i have a edge cs i just picked up also but cant figure out how to agjust the speedometer, can anyone help i am running 37/13.5/r18 and i have already gotten a speeding ticket lol. is ther any one out there that can help?
quacksmacker101 is offline
post #2 of 9 Old 06-14-2014, 02:58 PM
trophy_23's Avatar
Use the SCT tuner to change Rotations per mile maybe? You can input your tire size on the insight menu also and it will give you corrected speed.
2007 F350 SC FX4 Lariat
Edge Insight CS w/ Pillar Mount & EGT
SCT with Gearhead Tunes
ARP Studs & EGR Delete
High Idle
Duraflaps
Back Rack & Tool Box
LED bed & toolbox Lighting
4 Hella's Behind the Grille
18W LED Hitch-mount Back-up Lights
Dually ID Bar
**You could be the one match to save a life!!**
trophy_23 is offline
The Following User Says Thank You to trophy_23 For This Useful Post:
quacksmacker101 (06-14-2014)
post #3 of 9 Old 06-14-2014, 03:28 PM Thread Starter
thanks man i really aprreciate it, on the insight it will only show the corrected speed on the monitor right?
post #4 of 9 Old 06-14-2014, 03:35 PM
trophy_23's Avatar
Yes thats correct. If you use the SCT you should be able to change the speedo I think. You have to find out the rotations per mile from your tire manufacturer though I think. I am just new to the programmers so Im sure someone else can confirm this is true.
High Idle
Duraflaps
Dually ID Bar
post #5 of 9 Old 06-14-2014, 05:04 PM
TheFordman87's Avatar
Not correct. SCT will only show correct speed from itself if it were the monitoring system. But you will be asked when making selection for custom tune. That is for your shift points mainly. Not your truck speedo. Correct speed when properly dialed in will show up on edge cs only
I'm addicted to diesel and I step on it constantly!
TheFordman87 is offline
post #6 of 9 Old 06-14-2014, 05:07 PM
Oh yeah I almost forgot if you want to correct your speedo you have to go to dealership or special order device I can't remember what one. I think none of them work for tires above either 30's or 37's I can't recall. But this was also about 2 years ago last time I heard. So maybe they have something new out there. Good luck bud
post #7 of 9 Old 06-14-2014, 05:46 PM
trophy_23's Avatar
That's what I said it will show on the edge only. The SCT part I wasn't sure about so thanks for that info, I knew it asked about tires but didnt know if it was for speedo or trans only.
High Idle
Duraflaps
Dually ID Bar
post #8 of 9 Old 06-15-2014, 07:08 AM Thread Starter
Thanks for the info guys I spent an hour messing with it and the edge says I am actually running 5 slower than my truck speedo. Which I do t think is right
post #9 of 9 Old 06-15-2014, 07:59 AM
trophy_23's Avatar
I have never been able to get mine right either. One thing I wish you could do on the insight is switch each parameter between imperial and metric individually.
High Idle
Duraflaps
Dually ID Bar
